Suspension & Brakes Theory, alignment, spring rates....
Mods for Sk2/ Omni UCA camber kits?
Old Sep 8, 2005 | 09:24 AM
Wilky's Avatar
Default Mods for Sk2/ Omni UCA camber kits?
I know there are posts out there covering this, but I can't seem to locate them when searching. So here goes...
1) Do the "new style" sk2/ Omni front camber kits still require modification (ie. hex-head bolts and washers)?
2) Are these "new style" kits still the same across the board? (Blox, Omni, Skunk, Megan)
3) If they are different, what are the differences??
4) When people refer to the "new style," what exactly has changed?
thanks
Old Sep 8, 2005 | 11:34 PM
Wilky's Avatar
Default Re: Mods for Sk2/ Omni UCA camber kits? (Wilky)
Bump. Someone has to know this stuff.
Old Sep 9, 2005 | 09:49 AM
Tyson's Avatar
only skunk2 has the "new" style, at least omni still does the old style. its a big improvement in durability over the previous way by sandwiching the arm.
Old Sep 9, 2005 | 10:11 PM
Wilky's Avatar
Default Re: Mods for Sk2/ Omni UCA camber kits? (Tyson)
Does it still require the new bolts and washers, as I have often seen stated by others?
Old Sep 10, 2005 | 09:46 PM
Wilky's Avatar
Bump!
Old Sep 11, 2005 | 10:55 AM
Wilky's Avatar
Bump for answers.
Old Sep 12, 2005 | 09:28 AM
PIC Performance's Avatar
I'm sure they included all the necessary hardware in their new camber kit packages. In the future, if you're really hard up for an answer and when searches and bumps don't turn up anything, you could try contacting the manufacturer/vendor directly.
Old Sep 12, 2005 | 10:10 PM
Wilky's Avatar
Default Re: Mods for Sk2/ Omni UCA camber kits? (Noob4life)
Werd. Thanks, but I don't think that the staff at Skunk 2 would be willing to give me info on how to improve on their product by replacing hardware and whatnot, but I could be wrong.
Old Sep 26, 2005 | 01:34 PM
Wilky's Avatar
Still curious.
Old Sep 26, 2005 | 01:36 PM
Tyson's Avatar
i wouldnt be sure of anything from skunk2. but it seems their redesign improved the robustness of their design, eliminating the need to replace the hardware.
Old Sep 26, 2005 | 09:40 PM
Wilky's Avatar
Thanks, that is kinda what I was looking for.
But... Does anyone know if Omni has done the same? I am looking to save a few bucks here.
Old Sep 26, 2005 | 10:08 PM
Tyson's Avatar
no. same old design.
Old Sep 28, 2005 | 11:30 AM
vain's Avatar
i've been using the revised skunk2 for almost a year - no slippage at all... which is nice. i didn't use any extra hardware (just what came with it).
only problem i have is that i'm too low ( and i'm not even dumped )... i'm getting dents from those arms up top
Old Sep 28, 2005 | 03:30 PM
Solracer's Avatar
Default Re: (vain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">only problem i have is that i'm too low ( and i'm not even dumped )... i'm getting dents from those arms up top </TD></TR></TABLE>
Do you have your Bumpstops in?
Old Sep 28, 2005 | 03:50 PM
vain's Avatar
Default Re: (Solracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have your Bumpstops in?</TD></TR></TABLE>
yeah. you've heard of that problem with skunk2 camber kits (and probably all the other ones like it)? that's the problem i'm having... cept mine's not as bad yet.
https://honda-tech.com/zerothread?id=645818
Old Sep 28, 2005 | 03:59 PM
Solracer's Avatar
Default Re: (vain)
https://honda-tech.com/zerothread?id=645818</TD></TR></TABLE>
Yep I have heard of It, I guess it happens becuase the Skunk 2 A-Arm is longer than a stock a arm.
Old Sep 28, 2005 | 04:09 PM
vain's Avatar
Yep I have heard of It, I guess it happens becuase the Skunk 2 A-Arm is longer than a stock a arm.</TD></TR></TABLE>
i didn't actually believe it'd happen to me... i'm not dumped or anything.. but its enough to make me want to try Ingall's or something.
Old Sep 28, 2005 | 04:15 PM
Tyson's Avatar
Default Re: (vain)
sigh... more reason not to bother buying omni/skunk2 suspension products. they just arent designed properly.
Old Sep 29, 2005 | 04:28 PM
vain's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">sigh... more reason not to bother buying omni/skunk2 suspension products. they just arent designed properly.</TD></TR></TABLE>
i haven't heard much about skunk2's coilovers... but i've heard horrible things about omni. i think in the future, i'll avoid that style of camber kits
KCUF_DB8
Suspension & Brakes
Feb 23, 2010 05:30 AM
nitrotiger
Suspension & Brakes
Dec 29, 2009 06:30 PM
cb1999nj
Mar 13, 2006 10:00 AM
peel17
Dec 5, 2005 02:32 PM
h0memade
Jul 24, 2004 09:40 PM
