how do u wire up the crank sersor for a zc motor in a crx 89 si
From: I told you to wait in the truck in Texas, United States
I have heard of people using the Si distributor
and leaving it wired as is..Not sure it that is true or not...
Otherwise you need to run the two extra blue wires from the
distributor plug to the wires on the camshaft sensor..
Looking at the 2 pin plug at the CPS with the harness side wires coming toward you. Clip UP.
The Left pin goes to ECU pin C2
The Right pin goes to ECU pin C1
h22_crx
11
Mar 9, 2006 11:49 PM
h22_crx
15
Mar 9, 2006 02:39 PM
99sonicbluegsr
Sep 16, 2004 07:43 AM
