The clutch on my RSX sounds like a squeaking door
Old Sep 8, 2005 | 06:27 AM
spectacle's Avatar
Default The clutch on my RSX sounds like a squeaking door
I wanted to post this thread on clubrsx but apparently I don't have enough posts or something.
Basically whenever I push or release the clutch SLOWLY it squeaks really bad. Cluch engagement seems to be unaffected. I top off the brake fluid in the reservoir so I know it isn't that. I remember reading somewhere on crsx that their was a bulletin put out about this being a problem with the slave cylinder but I am unable to find it again. Any insight?
Car is a 2002 Type S with 57k
Old Sep 8, 2005 | 07:07 AM
I cant believe this shit's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (spectacle)
Take some engine grease and put a dab of it on the moving joints under the dash.
Old Sep 8, 2005 | 08:06 AM
Inside the Torn's Avatar
I got a civic and the same exact thing happens to me, its been goin on for 20,000 miles and no problems at all.... but who knows, might be unrelated to yours
Old Sep 8, 2005 | 08:25 AM
Jonmon's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (I cant believe this ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I cant believe this **** &raquo;</TD></TR><TR><TD CLASS="quote">Take some engine grease and put a dab of it on the moving joints under the dash. </TD></TR></TABLE>
I used white lithium grease for mine. Never made a sound since.
Old Sep 8, 2005 | 10:23 AM
Slow EJ8's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (Inside the Torn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inside the Torn &raquo;</TD></TR><TR><TD CLASS="quote">I got a civic and the same exact thing happens to me, its been goin on for 20,000 miles and no problems at all.... but who knows, might be unrelated to yours</TD></TR></TABLE>
My Civic has been doin that too I have noticed. Wierd. Ill try the grease on the parts under the dash and see.
Old Sep 8, 2005 | 01:24 PM
The Captain's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (Slow EJ8)
i'm not sure if this would have anything to do with your problem, but in my 98 prelude, i get a squeek/grind noise when engaging the clutch, but this happens like once or twice every few months and i was told it could b my throwout barring. doesn't happen depressing the clutch tho
Old Sep 8, 2005 | 02:33 PM
E-Rok's Avatar
EPIC TUNING
Default Re: The clutch on my RSX sounds like a squeaking door (98silverlude)
Its a common problem on 2001+ civics as well. My 04 civic does it. I just turn the music up because apparently theres no fix for it.
Old Sep 8, 2005 | 02:36 PM
Default Re: The clutch on my RSX sounds like a squeaking door (rewsnaeht)
You just fixed it yourself.
Old Sep 8, 2005 | 03:16 PM
littlej72's Avatar
There is a fix, depends on where the squeak is for what method to use. Most common (super secret) I know this sounds ridiculous but, jack up the left front of the car(or put it on a lift) take of the left front wheel look into the rear portion of the wheel arch there is a small hole there if you look in it you will see where the clutch line is connected spray a silicone spray in there and if you can plug the hole, there are some updated parts as well but not worth it and not for all of em. trust me spray the silicone in there at where the line can move around spray it all over you wont hurt it, try it and let me know.
Old Sep 8, 2005 | 03:19 PM
DC5ITR329's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spectacle &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to post this thread on clubrsx but apparently I don't have enough posts or something.
I had the same problem. grease up the rod in the interior compartment.
Old Sep 8, 2005 | 09:08 PM
spectacle's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (aznbo1626)
my bad the problem related to the slave cylinder is for the clicking noise in the clutch, which I have by the way
Old Sep 8, 2005 | 10:24 PM
littlej72's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (blackdc5)
Read above post of mine, the other casuse is more rarely the actual pedal assembly, you can take the whole clutch pedal assy out and grease the pivots, rarely this is the problem and posts keep refering to the clutch slave, its actually the master that causes all the problems on rsx's (noise wise). I wont say what I do for a living but on average I probably work on as many rsx's in a month as you guys take dumps. eh....
Old Sep 9, 2005 | 01:46 AM
sleepinEP3's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (littlej72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlej72 &raquo;</TD></TR><TR><TD CLASS="quote"> its actually the master that causes all the problems on rsx's (noise wise). I wont say what I do for a living but on average I probably work on as many rsx's in a month as you guys take dumps. eh....</TD></TR></TABLE>
LISTEN TO HIM
had that problem since about 10k in my EP. just recently had my clutch master replaced under warranty. theres a TSB for my car, not sure if acura has one too but our cars are very similar and yours is an 02 just like mine.
Old Sep 10, 2005 | 04:53 AM
littlej72's Avatar
Default Re: The clutch on my RSX sounds like a squeaking door (sleepinEP3)
Yes same part(identical) same problem
Nisif
May 10, 2013 04:44 PM
ekb16a
19
Jun 29, 2009 11:27 PM
JDMBOY1904
Apr 17, 2009 11:35 PM
pleytes
Apr 11, 2008 11:42 AM
pcorad
Aug 15, 2005 01:53 AM
