Honda S2000 Honda S2000
catalytic converter
Old Sep 8, 2005 | 05:17 AM
spooniq's Avatar
Default catalytic converter
My catalytic convert is bent. I wounder if i can get if fixed or just buy a performance one. what kind of performence catalytic converters r good?
Old Sep 8, 2005 | 07:46 AM
WowOzYouRock's Avatar
Default Re: catalytic converter (spooniq)
ehh just get a test pipe ... but keep the cat for emission purposes
Old Sep 8, 2005 | 12:49 PM
OriginalFive's Avatar
Default cat
will the car pass emissions test with a test pipe? just wondering...
Old Sep 8, 2005 | 12:59 PM
Default Re: cat (OriginalFive)
as long as you dont have engine code ... get a simulator ... 96 and up or all OBDII is all plug in now ...
Old Sep 8, 2005 | 07:35 PM
spider2k's Avatar
you'll fail the visual though if they are paying attention.
Old Sep 8, 2005 | 07:36 PM
spooniq's Avatar
Default Re: cat (Y2K_S2K)
Where I live the oct is 91 . Will it past just with the test pipe? And how much hp would be gained?
Old Sep 8, 2005 | 08:46 PM
MarcosGonzalez's Avatar
Default Re: cat (spooniq)
you will gain a bit more power not that big of a difference. You will not pass smog but that is why you would keep your oem cat for that reason. You can make a mechanical O2 sensor simulator by getting 18mm sparkplug foulers for about $5. http://www.s2ki.com/forums/ind...29959 hopefuly that will help.
Dc2_ShowStopper
Honda CR-V & Element
Feb 5, 2013 05:07 AM
accordjuggalo1796
Dec 12, 2009 10:43 AM
preludefien
Mar 13, 2007 06:48 PM
Joel_MN
Apr 2, 2004 11:26 PM
caslmenow
Sep 11, 2002 04:51 PM
