Suspension & Brakes Theory, alignment, spring rates....
hard shaking while braking...
Old Sep 7, 2005 | 08:37 PM
h2392si's Avatar
Default hard shaking while braking...
hey peeps, got a 98 ex coupe and when i start to brake, my steering wheel starts to shake really bad. happens even more when i start to break from high speeds. any ideas what might be the culprit??
Old Sep 7, 2005 | 08:45 PM
blaqman's Avatar
Default Re: hard shaking while braking... (h2392si)
Warped brake rotors. This happens when you make a panic stop[ or something like dat, cuz u end up overheating the rotors, making them suceptible to warping. Change em and holla back! Might wanna go with a cross drilled slotted setup. BTW Get some good pads while ur @ it. Good luck homey.
Old Sep 7, 2005 | 11:06 PM
solareclipseauto's Avatar
Default Re: hard shaking while braking... (blaqman)
yeah check dem rotors
Old Sep 8, 2005 | 04:24 AM
00R101's Avatar
Default Re: hard shaking while braking... (solareclipseauto)
Before blaming the rotors (which will cost you money to fix), what you might have is some uneven accumulation of pad material on the rotors. Heating the rotors up with hard applications can sometimes clean the buildup off.. Do 4-5 hard stops from 60-10 then drive around at reaonable speeds without using the brakes for 5 minutes.
If that doesn't clear the problem up then I would look at the rotors next. If it is the rotors, don't waste money resurfacing them just buy new.
regards,
alan
Old Sep 10, 2005 | 04:01 AM
blaqman's Avatar
Default Re: hard shaking while braking... (00R101)
I was just saying, to save himself the time of troubleshooting a brake problem..... he might as well kill 2 birds with one stone and replace/upgrade his rotors which are probably years old. Anything else is a waste of time... (UPGRADE BRO!) Not 2 be rude just stating whats obvious 2 me.
Old Sep 10, 2005 | 09:24 AM
auslander's Avatar
While warped rotors can definately be the problem, all you need to do is have them turned. If they are warped too bad, any good shop should be able to tell you.
I had a similar problem on my '91 Integra and what the problem ended up being is the rear calipers. The cailper "floats" to accomodate pad wear. The caliper slides can get worn and let the caliper get bound up at an angle. If you take your calipers off and look at your pads the wear surface should be parallel to the backing plate. If it's at a funky angle, check your caliper slides. Even if the slides aren't worn, lack of lube (usually overlooked) can cause them to bind up. While a shaking wheel usually indicates the front brakes, my rear calipers shook the whole car so bad, it was impossible to tell. Hope this helps,
Mike
Old Sep 10, 2005 | 04:08 PM
macDelli's Avatar
Default Re: hard shaking while braking... (auslander)
try re-surfacing
BucCivicSi99
Suspension & Brakes
Mar 26, 2009 11:08 AM
nhlfan
Aug 23, 2005 02:33 AM
AFAccord
Jun 24, 2005 05:02 AM
PetroGuyX
Jun 26, 2003 02:10 PM
TsunamiZC
Oct 7, 2002 01:40 PM
