Installed GC on EP3
Old Sep 7, 2005 | 08:15 PM
Shingo's Avatar
Default Installed GC on EP3
i installed GroundControl on stock shock 2 1/2drop plan to get aftermarket shock.
Ride is alright ,but whenever i go to little bumps i hear
hitting noise from the front. like PHA!!!!
It the bumper hitting the ground or something else? Maybe it the wheel
IDK I need help
Modified by Shingo at 9:51 PM 9/7/2005
Old Sep 7, 2005 | 08:31 PM
Jaypee's Avatar
Default Re: Installed GC on EP3 (Shingo)
what's GC? I'm guessing it's suspension set up.
Old Sep 7, 2005 | 08:51 PM
Shingo's Avatar
Default Re: Installed GC on EP3 (Jaypee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaypee &raquo;</TD></TR><TR><TD CLASS="quote">what's GC? I'm guessing it's suspension set up.</TD></TR></TABLE>
Ground Control
Old Sep 7, 2005 | 10:46 PM
HiPhOpHeADs's Avatar
i have coilovers on stock shocks and the ride quality is kinda on the side, car bounces around a lot but it looks damn good
Old Sep 8, 2005 | 04:26 AM
kung fu grip's Avatar
on a 2.5" drop on stock shocks, you're probably slamming down on the bumpstops.
yeeesh.
Old Sep 9, 2005 | 04:27 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shingo &raquo;</TD></TR><TR><TD CLASS="quote">i installed GroundControl on stock shock 2 1/2drop </TD></TR></TABLE>
I know you don't want to hear this, but you probably want to raise the car back up about 1.5".
In addition to the clearance problem you've already noticed, you have introduced too much negative camber in the rear, and too much positive camber in the front, and you are also going to have a problem wherever you take the car to get it aligned.
What spring rates are you using?
Old Sep 9, 2005 | 01:13 PM
Groundcontrolstore.com's Avatar
Dose noise also occur when you turn your wheel at slow speeds?
Old Sep 9, 2005 | 02:50 PM
Shingo's Avatar
Default Re: Installed GC on EP3 (Groundcontrolstore.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Groundcontrolstore.com &raquo;</TD></TR><TR><TD CLASS="quote">Dose noise also occur when you turn your wheel at slow speeds?</TD></TR></TABLE>
No, im worried if my wheels are going to bend
Old Sep 9, 2005 | 03:09 PM
giff74's Avatar
What?
2.5" on an EP3 is a big drop. You could be hitting your bump stops and it could just feel like a big hit because your suspension now has no travel. Unless this thing is a full time race car and you have the camber all set I think you may want to raise it up a little.
Old Sep 9, 2005 | 03:50 PM
bricks2k4civic's Avatar
you need to raise it. I would recomend a tein Htech setup.
Midori Green
20
Nov 24, 2007 06:20 PM
accorkie
Suspension & Brakes
18
Jan 17, 2007 06:21 PM
cubism
Suspension & Brakes
May 21, 2006 12:22 AM
xgenn786
Sep 28, 2005 06:01 AM
MidNightPearlSi
Feb 29, 2004 09:30 PM
