FS : ITR FRONT SWAY BAR 24MMMMMMmm...
Old Sep 7, 2005 | 07:12 PM
jEE's Avatar
jEE
Default FS : ITR FRONT SWAY BAR 24MMMMMMmm...
FS : 2 oem itr 24mm front sway bar
$30.00 o.b.o (The one with out endlinks)
$45.00 o.b.o (The one with endlinks)
I NEED CASH ASAP SO I CAN BUY MY FRIEND DINNNER !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 9, 2005 | 03:56 PM
jEE's Avatar
jEE
Default Re: FS : ITR FRONT SWAY BAR 24MMMMMMmm... (jEE)
upupuppupuppp
Old Sep 14, 2005 | 10:36 AM
db8xc1x39
Guest
Posts: n/a
is that OEM ITR? cuz i thought it was 22mm. do you have the rear one as well?
Old Sep 14, 2005 | 10:38 AM
hazard_one's Avatar
Default Re: FS : ITR FRONT SWAY BAR 24MMMMMMmm... (db8xc1x39)
22mm is the rear
Old Sep 14, 2005 | 11:00 AM
db8xc1x39
Guest
Posts: n/a
Default Re: FS : ITR FRONT SWAY BAR 24MMMMMMmm... (hazard_one)
so the front itr is 24mm?? will i feel a difference on a DB8 integra gsr with just the front sway for now ?? i know that the rear one has a pretty big impact on handling but what about the front? let me know if you have any experience with that or any input thanks
Old Sep 14, 2005 | 11:13 AM
mystikalstriker's Avatar
the front is about 2-3 mm more then stock tegs. difference i dunno but if you use the formula to get the rigitidy it should be stiffer. probably something that can be felt but don't quote me on that.
Old Sep 14, 2005 | 12:03 PM
95 integra's Avatar
Default Re: FS : ITR FRONT SWAY BAR 24MMMMMMmm... (mystikalstriker)
stock on most integras is 24mm, there may be a model out there thats a 22 (maybe an older LS 2dr.....maybe).
Old Sep 17, 2005 | 07:48 AM
jEE's Avatar
jEE
Default Re: FS : ITR FRONT SWAY BAR 24MMMMMMmm... (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">stock on most integras is 24mm, there may be a model out there thats a 22 (maybe an older LS 2dr.....maybe).</TD></TR></TABLE>
ls and rs have smaller front sway bars
and the gsr and the type R have the 24mm.
Old Sep 17, 2005 | 08:41 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jEE &raquo;</TD></TR><TR><TD CLASS="quote">
and the gsr and the type R have the 24mm. </TD></TR></TABLE>
Indeed you are correct. The LS (RS/GS/SE) have a 22.1mm bar from 94-99 (both 2dr and 4drs) and then in 00-01 they are upgraded to 24mm.
Old Sep 28, 2005 | 02:17 PM
3rdgenLS's Avatar
how much shipped to CA 90026 for the one w/endlinks?
Old Oct 9, 2005 | 03:07 PM
xoutlawz00x's Avatar
Default Re: FS : ITR FRONT SWAY BAR 24MMMMMMmm... (3rdgenLS)
will this fit on a ek with type r suspension.. if so how much shipped to 06606
drive4aliving
Dec 20, 2007 01:49 PM
sleeper101
Northwest (Sales)
Nov 18, 2007 11:02 AM
sol badguy
Apr 15, 2004 08:49 PM
Hasboro
Oct 12, 2003 11:18 PM
