BLOWN MOTOR?????
Old Sep 7, 2005 | 06:45 PM
GSR-Civic's Avatar
Default BLOWN MOTOR?????
awww man! I was driving to pick my brother up from school, then wait for my other brother to get out band practice... by the way i had to drive almost 30 miles to pick them up.. along highway 281 ( long highway )
anyways i'm driving and i pick them up then on the way back all of a sudded my freaking car shuts down! i'm liek wtf is going on here? this is a god **** HONDA! not a ford...
anyways it turns out that i didnt have any freaking oil in my car. well **** i thought i better go buy some oil in the nearest gas station... go I jogged for about 20 min and I finally got there ( i like to run ) anyways so i bought oil then walked back to my car and I added oil and the start started to turn over but just as it was going to turn over BANG! A LOUD THUMP INSIDE THE FREAKING ENGINE! i'm like ****! and my brother (merciful) is like ****!!
so yea~! i called my dad to tow us with hes truck and we just got here JUST NOW>>.. freaking $*uks! NOW i dont have a ******* CAR!!!!!!!!!
my car is a 97 Honda Civic EX by the way
I THINK I JUST BLOWN MY WHOLE MOTOR!!!
PLEASE TELL ME WHAT TO DO!
Old Sep 7, 2005 | 06:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: BLOWN MOTOR????? (GSR-Civic)
well you need to asses the situation.
see if the engine spins freely. judging by how you described the noise, you either welded a rod to the crank, or a rod let go. either way if it was one of those 2 you will need at least a shortblock. if you cant spin the engine over by hand, pull the pan down and see if anyh of the rods are blue.
there are 2 choices if the engine is terminal.
1 - rebuild.
2 - easier, replace it.
Old Sep 7, 2005 | 06:52 PM
520_Motorsports's Avatar
does it turn over at all? if so do a compression test. if you have compression drain the oil and check it out even the new oil you have in it will show signs. if you lost a bearing or locked the motor by running no oil( probably most likely) then i would recommend a new engine. d16y8 right.
Old Sep 7, 2005 | 06:54 PM
GSR-Civic's Avatar
OH MY GOD! THIS CANT BE HAPPENDING TO ME i cant belive this!
Old Sep 7, 2005 | 07:11 PM
MyPocketsAintEmptyCUZZZ
Guest
Posts: n/a
pull the motor... rebuild it... its easy, its a D-series... cheap parts...
then put it back together and boost that ****!
Old Sep 7, 2005 | 09:07 PM
GSR-Civic's Avatar
i dont really know how to work on engines!
Old Sep 7, 2005 | 09:18 PM
.Ry's Avatar
.Ry
Default Re: (GSR-Civic)
Do a search through your local junkyard. See if they cant track one down for you for cheap. As a learning expericence get a few freinds, rent a cherry picker and put it in yourself. If that doesnt work call around to a few shops see what they would charge. A used motor for that car shouldnt be to high. I know a used D15b7 was like 300 with low miles so shoudnt be hard to find a D16. Calm down, it will all work out man.
Old Sep 7, 2005 | 09:53 PM
Bond's Avatar
Default Re: (turner7205)
That sucks. Prolly welded the piston to the cylinder walls and when you went to start it the rod prolly let go. Buy a used motor and swap it in. You could buy a cheap D15 and rebuild the Y8 and swap them when it's all rebuilt.
Old Sep 7, 2005 | 10:39 PM
Redline it.'s Avatar
like ur name says....buy a gsr engine and swap ur civic
Old Sep 7, 2005 | 11:21 PM
vancoland's Avatar
d16y8's are hella cheap...you don't have anything to worry about...and it only takes a day to swap that engine...your friends could help you and if you need more help....thats what ht is for
oh yea...did you find out where the oil went?...or where it leaked out from?...should be signs from the new oil you put in
Old Sep 7, 2005 | 11:36 PM
dantastic's Avatar
a decent mechanic should be able to swap in a used motor for ~$1000 w/ some sort of warranty. btw, ford or honda, your motor is going to go to **** if you don't check the oil.
Old Sep 8, 2005 | 12:59 AM
Dark_Kiseki's Avatar
dude just sell the car and get another its alot more easier
Old Sep 8, 2005 | 04:36 AM
GSR-Civic's Avatar
I want to thank everybody for there comments... I think I will try to find a cheao motor and try to put it in.. with help from my dad and honda-tech
I still can't belive this has happend to me.... stuff never happends to me... oh well.. theres people in this world who gots it tuff..
again thanks everybody H-T rules
Old Sep 8, 2005 | 07:05 AM
james p.'s Avatar
Theres a dip stick for a reason.
Use it, cause if you don't stuff like this happens. Believe me I know, the same happend to me.
Besides checking your oil, you should be checking your radiator and fluids once in a while. I know it's too late now but keep it in mind for the future.
Good luck with your rebuild or swap.
Old Sep 8, 2005 | 08:06 AM
civicholo's Avatar
that's why they have chilton's manuals, so you can work on them. it is a hell of a lot cheaper to do the **** yourself. i know. i had to replace the head on my car with a 97 ex head. the books are there for a reason!!
Old Sep 8, 2005 | 07:42 PM
Bond's Avatar
Default Re: (civicholo)
Stop shouting!!! Yeah chiltons is alright for your weekend DIY, but a Helms will give you a better information base with tones of pictures. If you do rebuild then get a Helms as it will make things way easier .
Old Sep 8, 2005 | 07:48 PM
FredoSP's Avatar
Take it to Gunn Acura in San Antinio, right off 10, I think Mark (a HT member) still works there.
Old Sep 8, 2005 | 08:26 PM
brad 1.BANNED's Avatar
Default Re: (FredoSP)
hahahah why dont people just check their oil every couple of days?
Old Sep 9, 2005 | 12:23 PM
Excrucio's Avatar
assess the damage if it turs out the motor is trash, and your dad dont mind a road trip, I have a few single cam motors lyin around i'd let go cheap
Old Sep 9, 2005 | 05:38 PM
(puma)'s Avatar
time for a b-series swap!! damn dude that sucks, dont feel bad though, time for a swap.
Old Sep 9, 2005 | 05:58 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (Bond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">That sucks. Prolly welded the piston to the cylinder walls and when you went to start it the rod prolly let go. Buy a used motor and swap it in. You could buy a cheap D15 and rebuild the Y8 and swap them when it's all rebuilt.</TD></TR></TABLE> I concur, a swap would be the easy, quick and assured fix. You could waste big time and some $ just to find out this is the direction you have to head anyway.
Oh and BTW it ok to ****** swear on this ****, and if any stupid ***** give you **** about it tell em to shove it up their *** and go **** themselves. LMAO. Who made em swear words anyway. Some guy was just like "**** is no longer a socially acceptable word for ones vocabulary."
Anyway, yeah swap it out.
Old Sep 9, 2005 | 06:04 PM
graveltravel's Avatar
eye eye cap'n!
Old Sep 10, 2005 | 08:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-Civic &raquo;</TD></TR><TR><TD CLASS="quote"> I think I will try to find a cheao motor and try to put it in..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DuMa Slow Wah &raquo;</TD></TR><TR><TD CLASS="quote">like ur name says....buy a gsr engine and swap ur civic </TD></TR></TABLE>
Old Sep 10, 2005 | 08:59 PM
SCCrules's Avatar
that sucks dude. my friends 93 lude si was burnin oil, but we caught it just in time. I would just buy another D16Y8. They're pretty cheap from what I've seen.
shookones2
Feb 13, 2008 09:55 AM
speedooo
Mar 7, 2007 01:46 PM
jaywoodz
Feb 5, 2007 09:24 AM
StreetEG
10
Jun 2, 2005 08:55 PM
Robstunner4
May 10, 2005 04:41 AM
