97 DX motor into 90 DX
Old Sep 7, 2005 | 06:01 PM
dohdoh420's Avatar
Default 97 DX motor into 90 DX
superhonda.com is a little slow so I'll try here;
I was just wondering if I could put a 1997 civic dx motor into my 90 dx with out alot of major work, I have already done a mpfi swap along with an SI tranny, will the 97 long block bolt right in/on to my manifolds, and will I be able to use my obd0 injectors, wiring etc.? all I will have to do is transfer my old d16 distributor over to the 97 head right? let me know asap, also how much do you think a 1997 DX shell would sell for, is $950 a good deal?
Modified by dohdoh420 at 7:13 PM 9/7/2005
Old Sep 7, 2005 | 07:09 PM
dohdoh420's Avatar
Default Re: 97 DX motor into 90 DX (dohdoh420)
anyone?
Old Sep 7, 2005 | 09:07 PM
dohdoh420's Avatar
Nobody knows if this swap is possible? bump for the night
Old Sep 7, 2005 | 10:15 PM
lodo1's Avatar
yes the motor will work. just use your wiring harness, and everything will work fine, you will need to use your intake manifold also
Old Sep 7, 2005 | 10:16 PM
lodo1's Avatar
and reuse your driverside mount
Old Sep 8, 2005 | 05:07 AM
vtecn8ive's Avatar
Default Re: 97 DX motor into 90 DX (tdocrx)
You will need 88-91 CRX/Civic driver side mount/bracket.
Matters what kind of tranny you have if you have 89-91 You can simply put it right on the long block (if it has flywheel/clutch combo). Otherwise if its an 88 tranny you will need that flywheel and clutch combo.
You can use its manifold or yours. Either will work. The 97 intake manifold may require some switching around of vacuum lines, iacv sensor, and a coolant line. otherwise just use everything from the d16a6 and put it on here. Use the a6 dizzy and ecu.
-shane
Old Sep 8, 2005 | 07:31 AM
CRXDrew's Avatar
ur also gonna have to wire up a fan switch, Y7 has a diff sensor on the long block... no big deal though
MastaFlyMason
Aug 19, 2016 05:33 AM
armandotyper
Feb 5, 2003 09:17 PM
