Mugen ECU and working ac..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mythias »</TD></TR><TR><TD CLASS="quote">Havent tried it. Then again, I dont have A/C or an mugen ECU.
lol same here
</TD></TR></TABLE>lol same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M »</TD></TR><TR><TD CLASS="quote">Any one tried this so that you can have AC with a Mugen ECU? </TD></TR></TABLE>
I haven't tried it in the present car, but something like that worked in my last 97 ITR with A/C and a Mugen ECU.
Essentially you just need to short the ECU control of the A/C system using the appropriate wires in the harness, obviating the ECU aspect. I'll be doing this in a few weeks when I replace the A/C belt and idler pulley, along with the PS belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryce Lynch »</TD></TR><TR><TD CLASS="quote">I haven't tried it in the present car, but something like that worked in my last 97 ITR with A/C and a Mugen ECU.
Essentially you just need to short the ECU control of the A/C system using the appropriate wires in the harness, obviating the ECU aspect. I'll be doing this in a few weeks when I replace the A/C belt and idler pulley, along with the PS belt.</TD></TR></TABLE>
I was told that this will take out the WOT ac clutch cut out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M »</TD></TR><TR><TD CLASS="quote">I was told that this will take out the WOT ac clutch cut out?
That does seem to be a likely result of bypassing the ECU.
I'm running the Mugen ECU in my 97 ITR at the moment, but since I had a failure in the bolt holding the tensioner pulley bracket (i.e., no AC for me at present), I haven't clipped and re-wired the harness in this car yet.
I've also had a harness adapter with a VAFC in the car at times, and may modify that instead of the car's wires. But that will have to wait ... for now.
Oh, one last thing.
With the Mugen ECU and A/C, sometimes it doesn't idle very well, or simply stalls when coming to a stop with the A/C on.
</TD></TR></TABLE>That does seem to be a likely result of bypassing the ECU.
Oh, one last thing.
Why would you want to run AC and the mugen ECU at the same time? I run my stock ECU when I want AC and Mugen the rest of the time. Gas milage is probably horrible with the combination of the Mugen ECU and AC. I know I get about 8 miles a gallon less when I run my Mugen ECU
jwaked
12
Dec 29, 2004 09:22 AM
