Evasive motorsports ob2-ob1 harness
Dont buy the Evasive motorsports ob2 to ob1 wiring harness. I am on my second one now and its having the same problem as the first one. The wires are coming lose from the connectors.
my frend ordered the xenocron obd0-obd1 harness.. p05 to vtec conversion chip tuned for b16.. everything came very nicely packaged with DETAILED instructions... good person harness looks very nice..ill post a pic
I have the obd2a-obd1 harness. Works fine.
The only thing is with a 96-98 dx and up to 00 with obd2b, you must replace iacv with a two wire and relocate some pins and what not...
Evasive said that the harness is plug and play... ITS NOT. Or you will fry your y7 iacv, if you actaully plug and play with that harness.
mine were plug and play. The wires are came/ coming off the side where they used shrink tubing to hold it onto the plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mwsol »</TD></TR><TR><TD CLASS="quote">I have the obd2a-obd1 harness. Works fine.
Evasive said that the harness is plug and play... ITS NOT. Or you will fry your y7 iacv, if you actaully plug and play with that harness.</TD></TR></TABLE>
REDEM1FTW
13
May 11, 2010 10:08 AM
elmalouno
Apr 26, 2004 02:35 PM
