D16Z6 Clutch question
Old Sep 7, 2005 | 01:29 PM
92CivicSIRhb's Avatar
Default D16Z6 Clutch question
Ok, well i changed my clutch my self (First Time Ever) about 2 months ago. It's an exedy clutch. Well its slipping, but only when i am shifting at high RPM's. But since i have a lead foot i'm in high RPM's alot, so i need to figure this out. when i changed my clutch i didn't have money or time to get the flywheel resurfaced. could this be my problem. When i first installed the clutch it grabed fine. but now it doesn't grap as good.
Will i just need to get it resurfaced. or will i have to get a whole new clutch and a resuface job?
Help is needed
Old Sep 7, 2005 | 01:34 PM
Kyles ej1's Avatar
Default Re: D16Z6 Clutch question (92CivicSIRhb)
not resurfacing your flywheel caused premature wear and now you will need to replace both
Old Sep 7, 2005 | 01:35 PM
PRcivicHB's Avatar
yes not resurfacing, or improper break in can cause slipping...
I actually did the same thing, and not resurfaced my flywheel, same exact clutch and did not break it in either.... It also slipped, so what i did was take it easy on the car, and after a while it went back to normal... Dont know how but it did...
Old Sep 7, 2005 | 01:38 PM
what i was hoping is that i could just drop the trany and resurface the bitch. Now i have money and time. Think it would help?
Old Sep 7, 2005 | 03:39 PM
PRcivicHB's Avatar
if the surface of the flywheel was uneven it probally wore down your clutch uneven... soo now ur flywheel will be okay but your clutch might be off... hmmmmm..... I donno man.,... if you have the money, just get the clutch replaced, and resurface the flywheel... if not try your idea...
Old Sep 7, 2005 | 04:32 PM
siregcivic's Avatar
i would just replace the clutch and flywheel... its not worth the time to drop everything just to put the used crap back in... u dont have to replace ur flywheel just get it resurfaced.
lude98SH
Feb 21, 2006 07:28 AM
Confuc1ous
Mar 31, 2005 04:41 PM
punkkazzjoe
Sep 25, 2004 09:49 AM
abeaujuin
Jan 9, 2004 04:43 AM
