b18c all motor 240whp 180 torke
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomenai »</TD></TR><TR><TD CLASS="quote">i have a integra gsr 94 mi last numbers in the Dino are 217 whp and 165 torque mi goal is 240whp and 165 torque is possible???</TD></TR></TABLE> what's your setup?
86 mm bore 95 mm stroke
12.5 comp arias pistons
original head gasket
stage 3 cams
titanium valve spring and retainers
type r intake
70mm throttle body
3" air cold intake
type r header and 3" cat back
hondata s2
350cc inyectors
stage 3 cams
type r intake
70mm throttle body
3" air cold intake
hondata s2
350cc inyectors
go better header (custom), bigger injectors, 440's at least, edelbrock intake manifold and port job.
you should make the torque numbers you want with that crank and real close
with the hp if you take care of the other stuff.
good luck.
good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAM562racing »</TD></TR><TR><TD CLASS="quote">go better header (custom), bigger injectors, 440's at least, edelbrock intake manifold and port job.
good luck.
I totally agree! With the size of your motor you have exceptional potential! The most important things now are a GREAT HEADER, YOU NEED bigger injectors, a GOOD INTAKE mani and also HEADWORK and CAMS are needed in an all motor set up. Combination combination combination!!! Also GET A GOOD TUNE!!!!
good luck.
</TD></TR></TABLE>I totally agree! With the size of your motor you have exceptional potential! The most important things now are a GREAT HEADER, YOU NEED bigger injectors, a GOOD INTAKE mani and also HEADWORK and CAMS are needed in an all motor set up. Combination combination combination!!! Also GET A GOOD TUNE!!!!
this car was modified in INLINEPRO http://WWW.INLINEPRO.COM the make nice engines turbos and all motor. Mi name is Luis Landero. i now i need a better header but i don't now weer to go to make one custom made. One day i left only the header w out exhaust and o mean i was really really a BIG BIG DIFFERENCE
. sorry i can't post the dyno
hmm, i wonder if i have ever met you.
were was it dynoed at? batlgound, balanced performance, knowledge performance, etc?
If you need a custom header PM me, i can put you in touch with RMF or SMSP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomenai »</TD></TR><TR><TD CLASS="quote">full race</TD></TR></TABLE>
LOL!! Full Race what? Full Race Motorsports does not make cams ESPECIALLY not some NA cams. Explain who Full Race is?
12.5 compression and stage 3 cams, and i think your saying they are Full Race cams.....if your not being real discrete about your setup, then your just spitting out what you most commonly read on the internet or something. just looks like that.
btw, what kind of tq curve you looking for and at what rpms?
