radiator cap
Old Sep 7, 2005 | 11:20 AM
Captn Shakelford.'s Avatar
Default radiator cap
ive got a fluidyne radiator(92up) in my 90 si hatch and was wondering if anyone else has had any problems out of the rad. cap they send? damn thing is a bitch to get on and off. My motor is just a stock b16 and i dont think i need a "performance" cap but are the "spoon" rad. caps worth the money or is it just "bling"
Modified by t3h WIN at 12:32 PM 9/7/2005
Old Sep 7, 2005 | 06:12 PM
UsDm_Junky's Avatar
iv never heard of a performance radiator cap or have any idea how one radiator cap could out perform another.... do you mean is one easier to tighten than another or what? you lost me
Old Sep 7, 2005 | 06:22 PM
Crimson_Tide's Avatar
Default Re: (UsDm_Junky)
some radiator caps raise the amount of pressure inside a cooling system... therefore the boiling point of the coolant is raised... for instance... coolant in a cooling system with a 16 psi radiator cap would be able to reach a higher temp. without boiling than a system that had a 14 psi cap... as far as would it be worth it i think that its always worth it to have some "insurance" just incase something happens
-Josh
Old Sep 7, 2005 | 06:35 PM
ClimaxCRX's Avatar
Default Re: (Crimson_Tide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">some radiator caps raise the amount of pressure inside a cooling system... therefore the boiling point of the coolant is raised... for instance... coolant in a cooling system with a 16 psi radiator cap would be able to reach a higher temp. without boiling than a system that had a 14 psi cap... as far as would it be worth it i think that its always worth it to have some "insurance" just incase something happens
-Josh</TD></TR></TABLE>
Old Sep 7, 2005 | 06:36 PM
thanks buddy
Old Sep 7, 2005 | 07:13 PM
UsDm_Junky's Avatar
who sells these kind of caps?
Old Sep 7, 2005 | 07:18 PM
http://www.ebay.com
Old Sep 7, 2005 | 07:27 PM
teler86's Avatar
Default Re: (t3h WIN)
has anyone gotten an ebay radiator cap i dont think they are legit
Old Sep 7, 2005 | 10:08 PM
D Grade's Avatar
Default Re: (teler86)
Go to Schucks/Checker/Kragen autoparts store and look in the radiator caps section. Find the Prestone radiator caps, and look for RSP-27 and RSP-33. The RSP-27 is a 13psi cap and is the one that will come up for the CRX in their computer. The RSP-33 is the same cap, but uses a 16psi spring instead. The RSP series comes with a little red flip down safety guard.
The caps are about $8 and are just as pretty and work just as well as the obsurd $30-$40 Spoon cap.
ls19integra95
Jan 30, 2008 09:21 PM
mingbling96
Jul 1, 2005 05:50 PM
95blk2draccordEXMT
Jul 23, 2003 10:00 AM
94GSRRacer2
May 8, 2002 08:04 PM
