Valve Clearence?????? B16 head w/ type R cams
Old Sep 7, 2005 | 10:45 AM
rfuentes29's Avatar
Default Valve Clearence?????? B16 head w/ type R cams
Any one know what the clearence is supposed to be?? I have a B16 Vtec head w/ Type R cams. I think it's 007mm intake and 008mm exhaust.
Is that right??
Old Sep 7, 2005 | 10:51 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Valve Clearence?????? B16 head w/ type R cams (devilman INC.)
006-007 intake, 007-008 on exhaust
Old Sep 7, 2005 | 01:40 PM
rfuentes29's Avatar
thanks
Old Sep 12, 2005 | 04:18 PM
rfuentes29's Avatar
Default Re: (devilman INC.)
ok
i did .006 intake and .007 exhaust
now she smokes like a champ??? what should i do? i also hear a clattering noise when i stomp on the throttle at low rpm's, the noise goes away once vtech kicks in???
Old Sep 12, 2005 | 04:27 PM
rfuentes29's Avatar
oh, and the car runs pretty rough also...
Old Sep 12, 2005 | 04:58 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilman INC. &raquo;</TD></TR><TR><TD CLASS="quote">Any one know what the clearence is supposed to be?? I have a B16 Vtec head w/ Type R cams. I think it's 007mm intake and 008mm exhaust.
Is that right??</TD></TR></TABLE>
The correct clearances are:
IN 0.006" - 0.007"
EX 0.007" - 0.008"
If you are measuring in metric, the specifications are:
IN 0.15mm - 0.19mm
EX 0.17mm - 0.21mm
Old Sep 12, 2005 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilman INC. &raquo;</TD></TR><TR><TD CLASS="quote">ok
now she smokes like a champ??? what should i do? i also hear a clattering noise when i stomp on the throttle at low rpm's, the noise goes away once vtech kicks in???</TD></TR></TABLE>
Where did you slide your feeler gague?
Old Sep 12, 2005 | 05:24 PM
rfuentes29's Avatar
Default Re: (PURPLETERROR)
ok, so i did .006 all the across the intake side and .007 all the way cross the exhaust side. is that right? i slide my feeler gauge between the bottom of the cam lobe and the rocker...
i just took it for a drive, the smoke seemed to stop after a while, but still clatters and runs rough.
Old Sep 12, 2005 | 05:54 PM
try going 007 in 008 exhaust, it sounds like your valve lash is to tight
Old Sep 12, 2005 | 07:15 PM
rfuentes29's Avatar
some one told me that the clattering noise is pre-detnation caused by timming being off, too much compression, or cylanders running alittle hot...
also smells like lots of fuel coming out the exhaust. and carbon crap splashes out at startup.
Old Sep 12, 2005 | 07:20 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilman INC. &raquo;</TD></TR><TR><TD CLASS="quote">some one told me that the clattering noise is pre-detnation caused by timming being off, too much compression, or cylanders running alittle hot...
also smells like lots of fuel coming out the exhaust. and carbon crap splashes out at startup.</TD></TR></TABLE>
damn i dont think your lash is out, sounds like you need a tuneup...lol
what block you have a stock B16??
Old Sep 12, 2005 | 07:24 PM
JDM JEFFREY's Avatar
check the lms
Old Sep 12, 2005 | 07:39 PM
rfuentes29's Avatar
i have a b18 block with type r pistons on ls rods, type r oil pump, b16 head with type r intake manifold and cams.
Old Sep 14, 2005 | 08:57 AM
rfuentes29's Avatar
what's a lms
Old Sep 14, 2005 | 12:15 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilman INC. &raquo;</TD></TR><TR><TD CLASS="quote">what's a lms</TD></TR></TABLE>
he means LMA's=lost motion assemblies
but that would have nothing to do with your car and all those symptoms..
Old Sep 14, 2005 | 01:29 PM
rfuentes29's Avatar
what timming belt should I be using? Right now it's a LS timmimg belt. Should I be using a vtec timming beld?
Old Sep 19, 2005 | 02:47 PM
ItrpwrdCrx's Avatar
also smells like lots of fuel coming out the exhaust. and carbon crap splashes out at startup.</TD></TR></TABLE> ive got the same problem..did u get urs fixed?
Old Sep 19, 2005 | 03:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilman INC. &raquo;</TD></TR><TR><TD CLASS="quote">what timming belt should I be using? Right now it's a LS timmimg belt. Should I be using a vtec timming beld?</TD></TR></TABLE>
if you are using the ls water pump, you use the ls belt, if you are using a vtec waterpump, you use the gsr/itr belt
Old Sep 20, 2005 | 04:32 PM
rfuentes29's Avatar
I'm going to get my car tuned with Hondata.
Old Sep 20, 2005 | 05:04 PM
RudeBwaiSi's Avatar
I think the clattering sound occurs when the valves are loose.
Old Sep 21, 2005 | 03:21 PM
rfuentes29's Avatar
Default Re: (RudeBwaiSi)
No, its when you detonate. My Ecu isn't tuned for Type R internals. Timming is off and air/ fuel is off. Hope the hondata fixes every thing. After I get it tuned, I'm going to post the results. Wish me luck
jrp355
Dec 9, 2011 10:57 AM
GarretCRX
Mar 22, 2007 11:13 AM
ramtyper19
Oct 5, 2005 08:09 PM
Used2beAb16
Mar 19, 2004 03:52 AM
Nextelbuddy
May 30, 2003 11:01 AM
