Having clutch and flywheel replaced, what other parts should be replaced
Old Feb 26, 2002 | 04:49 PM
Mt3c's Avatar
25 Year Member
Default Having clutch and flywheel replaced, what other parts should be replaced
high mileage; 140000 on a 94 GSR
here are parts to be ordered:
(ITR clutch pack)
22300-P73-025 PRESSURE PLATE
22200-P73-R01 FRICTION DISC
22100-P73-005 FLYWHEEL
91006-634-008 PILOT BEARING
90034-689-000 CLUTCH BOLT
90011-PH3-000 FLYWHEEL BOLT
Other parts that i have found through search:
Release bearing
Rear main seal (where does this go?)
Did i miss anything?
Old Feb 26, 2002 | 04:55 PM
Jesse H's Avatar
Default Re: Having clutch and flywheel replaced, what other parts should be replaced (Mt3c)
and a little over 2 quarts of honda tranny fluid and you'll be good to go.
as far as clutch and pressure plate bolts, those are ok to reuse unless you have some stripped on crossthreaded.
If you're doing the work yourself, a clutch alignment tool will be handy.
Old Feb 26, 2002 | 05:45 PM
Mt3c's Avatar
25 Year Member
Default Re: Having clutch and flywheel replaced, what other parts should be replaced (Jesse H)
thanks for the quick reply, looks like i'll be ordering these parts tomorrow morning.
Old Feb 26, 2002 | 06:09 PM
vhd's Avatar
vhd
it would a good idea to replace the release(throw-out) bearing since your doing a clutch job
Old Feb 26, 2002 | 06:23 PM
GTM's Avatar
GTM
Always replace not just the throwout/release bearing, but also the pilot bearing located behind the flywheel. You can simply knock it out with a small hammer and gently tap the new one in place. At your mileage, it is also a good idea to replace the rear main seal.
All these parts except the rear main seal should be included in a quality clutch set.
Old Feb 26, 2002 | 06:25 PM
liquidlife's Avatar
Yes, everyone is right on target. You don't need the bolts. Sounds like you are having the work done? If you had the time, I highly recommend getting your flywheel lightened, or an aluminum one. I love mine. It really helps to get the car reving. The sooner you are in your power band, the faster you are.
The rear main seal is a gasket that is behind the flywheel. REPLACE IT. All of the money you dumped into the clutch could be wasted if your seal begins to leak.
Old Feb 26, 2002 | 07:34 PM
Mt3c's Avatar
25 Year Member
Default Re: Having clutch and flywheel replaced, what other parts should be replaced (liquidlife)
wow, i guess i was on target with the things i listed above. thanks again everybody for the suggestions.
liquidlife- i thought the itr flywheel was already 4~5 lbs lighter than the gsr flywheel. I'm just going to keep it the way i get it to keep the cost down.
-David
Old Feb 27, 2002 | 06:18 PM
D.Lansing's Avatar
how much are you getting your itr clutch parts for? Im replacing my clutch and flywheel as well and while Im fully decided on the flywheel (toda) I haven't made up my mind as to an exedy organic or itr clutch.
Old Feb 27, 2002 | 07:25 PM
Mt3c's Avatar
25 Year Member
Default Re: Having clutch and flywheel replaced, what other parts should be replaced (D.Lansing)
check out http://www.typerparts.com
Old Sep 10, 2003 | 01:41 PM
IntEGNYC's Avatar
Will these parts fit into my LS tranny?
Old Sep 10, 2003 | 01:43 PM
EL Vap133's Avatar
Default Re: Having clutch and flywheel replaced, what other parts should be replaced (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">Will these parts fit into my LS tranny?
What parts?
Old Sep 10, 2003 | 03:12 PM
hypa's Avatar
If you're talking about the clutch, all B series clutch parts will work with all b series motors.
m015094
Feb 19, 2007 11:44 AM
leewal
Sep 10, 2006 11:37 AM
SD_EM1
Jul 26, 2003 10:33 AM
lionhart
Apr 18, 2003 09:19 AM
3rdGteg
Jul 18, 2002 11:48 PM
