Tranny Swap Honda Del sol 94
Ok i am sure that you guys have heard this plenty of times, and I heard it is a stupid way 2 go, but I am just really curious. I currently have a Del Sol 94 Automatic and I wanna convert to a 5 speed. I went to the Honda Dealer and they gave me a list of parts I need. (If you wish Ill post the parts they gave me) A near by place will do the labor for 750, but I was wondering if I am able to do it myself, or if there is a cheaper way to go other then buying another Del sol 94, I heard that alot of times, and AGAIN i am just very curious, if there is a good way to do it then ill do it. Just need your advice and help and suggestions. Thanks ahead of times. LAte
First off read this thread it has a lot of good info with a parts list which is close to what you need.
https://honda-tech.com/zerothread?id=1337459
The major differences would be shift linkage because the civic wont work and mounts MAY be different. Post up the parts list they gave you and I can tell you what you need ect.
Ohhh hit me up with questions or Luserkid is pretty good with them as well. hes the author of the post I linked you.
I think if you would have searched this probably has been covered before.
thanks alot heres the parts list:
ECU
Clip
Lever, Change
****, Change Lever
Washer, Thrust
Bush, RR. Joint
Dust Seal A
Seat
Holder, Change Ball
Colr, Pipe Mounting
Dust Seal B, Change
Collar, RR. Joint
Rod, GearShift
Extension, Change
Rubber
Bracket, Extension
Rubber
Stopper
Bolt, Extension
Colr, Extension END
Nut, Self Lock (6mm)
"" "" (8mm)
Bolt, Flange (8x18)
o-ring (11X1.()
Bolt, Hex. (8X50)
Bolt-washer (8X40)
washer, Plain (6mm)
Pin, Spring (8X20)
bolt, Flange (8X45)
Pedal, Accelerator
Washer
Spring
Cover
wire, throttle
Seal, throttle cable
clamp, throttle wire
stay, throttle wire
switch assy., stop
switch assy. (12mm)
pedal assy., Brake
bush, pedal
pad, pedal stopper
spring, pedal return
collar, pedal
cover, pedal
bracket, pedal
pad
stopper
bolt
spring
pedal, clutch
bush, pedal pin
bush a
bush b
brkt, clutch pedal
bracket, footrest
Nut (10mm)
nut, flange (10mm)
bolt, hex. (10X25)
"" "" (10X70)
Bolt Washer (8x16)
"" "" (6X20)
nut, hex. (6mm)
"" "" (10mm)
"" "" (10mm)
"" "" (12mm)
nut washer (8mm)
washer, Plain (10mm)
pin cotter (2.5X18)
bolt, flange (6X12)
thats all if you need a certain part number tell me, and if you can go down the list and tell me what i dont' need just tell me k. thanks you really helped me.
ECU
Clip
Lever, Change
****, Change Lever
Washer, Thrust
Bush, RR. Joint
Dust Seal A
Seat
Holder, Change Ball
Colr, Pipe Mounting
Dust Seal B, Change
Collar, RR. Joint
Rod, GearShift
Extension, Change
Rubber
Bracket, Extension
Rubber
Stopper
Bolt, Extension
Colr, Extension END
"" "" (8mm)
Bolt, Flange (8x18)
o-ring (11X1.()
Bolt, Hex. (8X50)
Bolt-washer (8X40)
washer, Plain (6mm)
Pin, Spring (8X20)
bolt, Flange (8X45)
Pedal, Accelerator
Washer
Spring
Cover
wire, throttle
stay, throttle wire
switch assy., stop
switch assy. (12mm)
pedal assy., Brake
bush, pedal
pad, pedal stopper
collar, pedal
cover, pedal
bracket, pedal
pad
stopper
bolt
spring
pedal, clutch
bush, pedal pin
bush a
bush b
brkt, clutch pedal
bracket, footrest
Nut (10mm)
nut, flange (10mm)
bolt, hex. (10X25)
"" "" (10X70)
Bolt Washer (8x16)
"" "" (6X20)
nut, hex. (6mm)
"" "" (10mm)
"" "" (10mm)
"" "" (12mm)
nut washer (8mm)
pin cotter (2.5X18)
bolt, flange (6X12)
I got your IM, sorry i was knocked out. Email me for best responce since you cant recieve PMs yet.
Theres things you need and things you dont need. The post with the link, thats my thread. Although the parts list are close there off between 96 and up and 96 and down. Your going to want to look at this thread:
https://honda-tech.com/zerothread?id=1316692
Its the same list you need. Most of this stuff you could get at a junkyard for much cheaper then Honda too. Just make sure everything comes from a Del Sol.
if you want to know exactly how to do it on your exact car, e-mail me. ive done the exact swap myself and its NOT hard. its not worth 750 either. my going rate of a single cam 5 speed swap is 400.
Brett
Brett
