Question about SOHC ZC Motor????
Old Sep 6, 2005 | 07:57 PM
sleepy_hatch's Avatar
Default Question about SOHC ZC Motor????
I'm putting in a SOHC ZC Motor into a 88 Crx Si. Can I still use my old D16Y6 half shafts and the old motor mounts? Or will I have to get new ones? What about the ECU can I use my stock Si ECU?? Thanks for the info. I need to get this car running.
Old Sep 6, 2005 | 08:00 PM
crxdriver89's Avatar
Default Re: Question about SOHC ZC Motor???? (jpcrx-si)
you can use the same ecu, and the motor will drop right in, as to the half shafts, i don't know.
Old Sep 6, 2005 | 08:10 PM
Default Re: Question about SOHC ZC Motor???? (crxdriver89)
Thankyou!!
Old Sep 6, 2005 | 08:46 PM
turbodcivic510's Avatar
i think you can use the same ones, so your good to go...
Old Sep 6, 2005 | 11:37 PM
Tyson's Avatar
if youre not changing the tranny, the axles shouldnt change either.
transplant whatever intake manifold youre using over to the new engine and everything will work like before.
and whered you get d16Y6 axles? is that a typo? all i can find on that engine is that its an obd1 foreign engine.
Old Sep 7, 2005 | 07:30 PM
Default Re: Question about SOHC ZC Motor???? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">if youre not changing the tranny, the axles shouldnt change either.
and whered you get d16Y6 axles? is that a typo? all i can find on that engine is that its an obd1 foreign engine.</TD></TR></TABLE>
Sorry typo. thanks for the help. I don't have any other intake manifold.
Can I not use the same one on the motor it came with.
Old Sep 7, 2005 | 11:03 PM
Tyson's Avatar
i guess you didnt understand what i was typing.
to answer your question, yes. youre fine.
ef 4dr
23
Dec 20, 2007 04:54 PM
jdm_dc_fan
Aug 25, 2007 09:12 AM
BuddhistPriest87
Dec 8, 2006 05:36 PM
blackeg
Feb 23, 2005 08:34 PM
