cant get front springs off.....
ok i went to autozone and got a a spring compresser but the thing is it wont fit in the front springs.it did work and fit in the back tho.......what did u use to compress your springs???i have a 95 integra by the way
Go out into your yard, (the grass), have a buddy stand on the spring and you unscrew the nut until it pops off. Make sure your buddy helps keep an eye out for the exploding nut and washer. That's how I've done it in the past.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinese acrobat »</TD></TR><TR><TD CLASS="quote">^^ DONT DO^^</TD></TR></TABLE>
Don't be a wuss. It works fine. Just make sure it's pointed away from anything important. It only jumps like 6in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">Go out into your yard, (the grass), have a buddy stand on the spring and you unscrew the nut until it pops off. Make sure your buddy helps keep an eye out for the exploding nut and washer. That's how I've done it in the past.
^^^^^^^^^^Been there done it...... works fine. If n e 1 gets hurt it's their own fault!! J/k but =seriously its okay to try! The spring compressor that you compress with a drill is an accident waiting 2 happen imo. My 2centz.
</TD></TR></TABLE>^^^^^^^^^^Been there done it...... works fine. If n e 1 gets hurt it's their own fault!! J/k but =seriously its okay to try! The spring compressor that you compress with a drill is an accident waiting 2 happen imo. My 2centz.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaqman »</TD></TR><TR><TD CLASS="quote">
^^^^^^^^^^Been there done it...... works fine. If n e 1 gets hurt it's their own fault!! J/k but =seriously its okay to try! The spring compressor that you compress with a drill is an accident waiting 2 happen imo. My 2centz.</TD></TR></TABLE>
vinuneuro
Suspension & Brakes
Mar 28, 2008 05:14 AM
