Confused about spring rates
Im looking into coilovers and getting specific springrates and all that good stuff
As im looking around i see people talking in different measurment methods. I see some people using lb/in (400 lb/in-350 lb/in) and then k (11k/9k)
Is there a method of transfering lb/in to k or are they not even related and mean totally different things?
I have searched and found no answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt87 »</TD></TR><TR><TD CLASS="quote">Im looking into coilovers and getting specific springrates and all that good stuff
I have searched and found no answer</TD></TR></TABLE>
lbs = lbs/inch
k = kg/mm
1kg/mm = 56lbs/in
so ....
11k = 616lbs
7k = 392lbs
400lbs ~ 7k
350lbs ~ 6k
oh yeah ... and if you forget 56 you can rely on google. I love google
Just put this in the google search and you'll get the answer:
7 kg/mm = ?lb/in
lbs = lbs/inch
k = kg/mm
1kg/mm = 56lbs/in
so ....
11k = 616lbs
7k = 392lbs
400lbs ~ 7k
350lbs ~ 6k
7 kg/mm = ?lb/in
DIRep972
Jan 5, 2004 05:02 AM
