Stupid ?= What size socket for ARP headstud nuts??
From: gravity rides everything...everything will fall, se GA/ne FL
should be 1/2" 12pt...i'd get a deep socket. metric 13mm 12pt works too i think, but it's standard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">should be 1/2" 12pt...i'd get a deep socket. metric 14mm 12pt works too i think, but it's standard.</TD></TR></TABLE>
14mm no worky. 6pt grabs a bit, but 12pt not at all
Sure it's 1/2"? "looks" a bit bigger than that.....
Bacl to the tool store I go....
.Sure it's 1/2"? "looks" a bit bigger than that.....
i'm sure i just checked a gsr arp nut and it's 1/2" or 13mm (edited). not 14mm.
it sucks removing it with just hand tools. i didnt have a pipe, so i used a 1" wrench as an extension on my 3/8 craftsman ratchet. it was a hell of a effort. i almost gave up. air tools are the best!
Dude the nut on the headstud is a 13mm spline socket. You do not want to screw those thigs up and make sure that you don't loose your washers that go with them.
You will need to get the 13mm deep socket
Hmm, when I had them, only a 1/2" worked. None of my metric ones worked well, they were a little loose. I wasn't about to torque head bolts/studs with a socket that was slightly loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">Dude the nut on the headstud is a 13mm spline socket. </TD></TR></TABLE>
What is a spline socket? My regular 13mm deep didn't work. Neither did any other metric one I had. I had to go to Sears to buy a single 1/2" deep. (Pretty much the only one that didn't come with my tool set
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec94civic »</TD></TR><TR><TD CLASS="quote">i noticed that it is 1/2" or 13mm 12pt for the b series and 12mm 12pt for the d series.</TD></TR></TABLE>
vtec94 you might be right the in my b-series it is a 13mm 12pt. so it might be a little smaller for the d-series. I think a 12 is pretty close to a half.
a spline socket is the one with all the different points on the inside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Germpeel »</TD></TR><TR><TD CLASS="quote">why didnt u just bring the nut with you the first time??
Because I didn't feel like draging my long block to the tool store.
Any more ?'s bright boy?
</TD></TR></TABLE>Because I didn't feel like draging my long block to the tool store.
Your mom is fat.
Edit:to politely answer all of your questions-
1. Yes I am taking them out. (not really an answer, more of a clarification.)
2.I posted it here because I'm taking them out of my ITR, and sometimes the <u>smart</u> people here have answers.
3. I only have 6pt sockets, you'll have to do the rest of the thinking on that one.
4.I didn't know what size they were, because I didn't install them. Also, I hardly ever post usless threads. Try searching the archives under my username.
5.Your mom is still fat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">Your mom is fat.
5.Your mom is still fat.</TD></TR></TABLE>
Yeah what he said.
Nah but really if it's a b series then it should be the multi point. 13 well I should say 12 pt
Yeah what he said.
Any more ?'s bright boy?</TD></TR></TABLE>
rofl.....
rofl.....
Well, there seem to be many responses in this thread.
Personally, I have worked with them AND had them in my own car. They were a 1/2" size. A 12 and 13mm did NOT work. The 12 didn't fit at all, the 13 went around the bolt, but was loose. I'm sure you don't want to be messing with headbolts/studs and loose sockets. That's the last bolt I want to be stripping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">should be 1/2" 12pt...i'd get a deep socket. metric 13mm 12pt works too i think, but it's standard.</TD></TR></TABLE>
this is for B series head stud bolts....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">Dude the nut on the headstud is a 13mm spline socket. You do not want to screw those thigs up and make sure that you don't loose your washers that go with them.
You will need to get the 13mm deep socket</TD></TR></TABLE>
NO IT IS NOT!!! it is a 1/2inch 12 point bolt.....
smartass
i love it
smartass
i love it
