switched to synthetic oil.. now car bogs
Old Sep 6, 2005 | 05:43 PM
blurrrcivic94's Avatar
Default switched to synthetic oil.. now car bogs
so I went from regular 5w30 to Mobil 1 5w30.. and now at idle my car will idle really low and rough, and sometimes shut off completely..
I read somewhere that this could be because synthetic oil tends to leak through seals in the combustion chamber if they are old.. if so, which ones is it most likely leaking through? I do wanna continue using synthetic if possible..
b16 btw
Old Sep 7, 2005 | 01:27 AM
Mr_Goodbar's Avatar
That's one reason. Ive also heard that because of the detergents in the synthetic, a lot of crap gets sorta loosened up and stuck in the system.
Old Sep 7, 2005 | 08:08 AM
Newark Built's Avatar
* B A N N E D *
Default Re: (Mr_Goodbar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Goodbar &raquo;</TD></TR><TR><TD CLASS="quote">That's one reason. Ive also heard that because of the detergents in the synthetic, a lot of crap gets sorta loosened up and stuck in the system. </TD></TR></TABLE>
Your sorta kinda on the right track with that assumption.
Especially on older motors, as you may or may not know, with normal or excessive wear, small grooves and scratches will form.
over time carbon will build up and sort of "fill" the scratches and groves.
With the addition if more/stronger detergents in the synthetic oil, the oil will clean up the carbon. And possibly cause your motor to burn oil.
Just my $.02
Dont hold me to it, most of it is logic and/or stuff i've seen/read.
Old Sep 7, 2005 | 08:13 AM
* B A N N E D *
Default Re: (Newark Built Kandy SiC-RX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blurrrcivic94 &raquo;</TD></TR><TR><TD CLASS="quote">
b16 btw</TD></TR></TABLE>
Backin up my first post,
The synthetic oil dosent leak through the seals,
Whats basically holdin your seals together is the build up of carbon, the synthetic cleaned out the carbon.
What you should do...
tear open that b16 and replace all seals have fun!
BTW- in my CRX i have a b16a also and when I changed over to sythetic it actually ran alot smoother, same thing with my girls 93 GS Teggy.
Try running 10w30 instead of the 5w30...see what happens
Old Sep 7, 2005 | 08:16 AM
vc's Avatar
vc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newark Built Kandy SiC-RX &raquo;</TD></TR><TR><TD CLASS="quote">Try running 10w30 instead of the 5w30...see what happens</TD></TR></TABLE>
jonyi27
Dec 28, 2012 11:43 AM
redDAinteg
Jun 4, 2006 11:17 PM
killaj12
16
Apr 13, 2006 01:52 AM
warwagon
Jun 4, 2005 08:24 AM
freeplay
Sep 13, 2003 02:16 PM
