is this normal?
if you stall... do you have to wait a bit b4 u start up the car? i need to give it a good minute b4 i can start it after it shuts off for some reason. my battery dying?
edit: this happened when my car was an automatic also. weird
Modified by idriveadelsol7 at 10:12 PM 9/6/2005
no thats not normal... please elaborate on what is going on.. what sounds does it make?? when does it stall. what year make modle what is done to it... the more info provided will help with diagnosis
it's a 94 del sol s w/ a jdm manual jdm d15b in there. like... when you stall... it's normal. nothing special about that.
but when i crank it back up it just cranks... and i have to wait a while before it starts up again. sometimes it would start up and just die. everything sounds normal too.
Is it getting gas after you stall? Not sure about your engine, but my 92 Si w/ a z6 had a similar prob. Turned out to be a combination of filthy fuel injectors, nasty fuel filter, and a failing main relay.
it turns on just fine when i start it up for the day... happened when it was an automatic also.
did an automatic/manual conversion and the engine is a jdm d15b instead of a d15b7.
Curlybandit
Aug 10, 2013 04:19 PM
crxsleeper210
Jul 1, 2013 02:26 PM
asletclark
16
Sep 5, 2012 04:21 AM
