SOHC VTEC ALL MOTOR GUYS, can i use a d16z6 cam on a d16y8??
Old Sep 6, 2005 | 01:51 PM
immikejones's Avatar
Default SOHC VTEC ALL MOTOR GUYS, can i use a d16z6 cam on a d16y8??
like the topic said, i want to buy a cam for my d16y8(96-98ex) and found one that is for a d16z6. its a ZEX cam stg2 let me know asap.
Old Sep 6, 2005 | 02:23 PM
Default Re: SOHC VTEC ALL MOTOR GUYS, can i use a d16z6 cam on a d16y8?? (immikejones)
up
Old Sep 6, 2005 | 05:09 PM
No-Gi's Avatar
yes, but you need an adj cam gear. Check out d-series.org. lots of info about this question there.
Old Sep 6, 2005 | 07:14 PM
d16vtecx's Avatar
Default Re: SOHC VTEC ALL MOTOR GUYS, can i use a d16z6 cam on a d16y8?? (3_South)
the y8 and z6 cam gears are a half tooth off
Old Sep 6, 2005 | 11:10 PM
Default Re: SOHC VTEC ALL MOTOR GUYS, can i use a d16z6 cam on a d16y8?? (d16vtecx)
If you use the Z6 cam, with a Y8 cam gear. And put this combo in a Y8 head, you don't have to retard the timing or advance the timing. it will be right.
is that true?? or will i still need a adj. cam gear and advance/retard 4.5 degree??
let me know. some guy just send me that info. yes or no?
Old Sep 7, 2005 | 07:29 PM
up again
Old Sep 7, 2005 | 08:21 PM
exsinnovation's Avatar
ttt
immikejones
Sep 7, 2005 07:55 PM
93-Z6-CX
Aug 18, 2005 11:07 AM
jjaskula1
Apr 3, 2005 10:50 AM
alexsracing
Feb 17, 2005 04:06 PM
mikehawkBUiLT
Sep 30, 2004 08:20 AM
