Type R compared to GS-R? Help please
I'm curious. I juat baught a type R that is being shipped to me from texas. Its been my dream car for years but never got to ride in one. I owned a 2001 Integra Gsr and liked it but like my friends 2000 civic si better. What I want to no is what does it feel like at vtec crossover in the type R compared to the gsr and si. Does it pull alot harder and kick in faster? Is it louder? Im talking with an intake only or stock comparisons. Thanks
Being that I've had both there is no compairison. It's like night and day. the R is much crisper in corners, much more raw feeling, faster, vtec "kicks" in harder and it's much more of a theft magnet.
CLASSIC.
I hate to just be a ******** and not helpful so I'll throw you a preverbial bone:
Type-R:
http://www.team-integra.net/se...ID=35
http://www.team-integra.net/se...ID=36
http://www.team-integra.net/se...ID=37
http://www.team-integra.net/se...ID=39
Specs:
http://www.team-integra.net/se....asp?
Engine
Model RS, LS, GS, SE GS-R Type R
Engine Code B18B1 B18C1 B18C5
Engine Type 1.8L, 4 cylinder, 16 valve, DOHC 1.8L, 4 cylinder, 16 valve, DOHC VTEC
Valvetrain 4 valves per cylinder, belt-driven, dual overhead camshafts 4 valves per cylinder, belt-driven, dual overhead camshafts, variable valve timing and lift with electronic control
Horsepower (hp), SAE net 142 @ 6300 RPM 170 @ 7600 RPM 195 @ 8000 RPM
Torque (lbs-ft), SAE net 127 @ 5200 RPM 128 @ 6200 RPM 130 @ 7000 RPM
Redline 6800 RPM 8100 RPM 8400 RPM
Bore x Stroke 8.1cm x 8.9 cm
(3.19 in x 3.50 in) 8.10 cm x 8.72 cm (3.19 in x 3.43 in)
Displacement 1834cc
(112 cu in) 1797cc (110 cu in)
Compression Ratio 9.2:1 10.0:1 10.6:1
Induction System Programmed Fuel Injection (PGM-FI) Programmed Fuel Injection (PGM-FI) with dual-stage intake manifold Programmed Fuel Injection (PGM-FI) with single-port intake manifold
Ignition System Electronic Ignition Electronic Ignition with knock sensor
Powertrain Transverse front engine, front wheel drive (FF) with equal length halfshafts to reduce torque-steer.
Engine Block Aluminum alloy with cast-iron cylinders
Cylinder Head Aluminum alloy
Emission Control 3-way catalytic converter
Tune-up Interval 100,000 miles
Transmission
(4-Speed Automatic) RS, LS, GS, SE
(5-Speed Manual) GS-R
(5-Speed Manual) Type R
(5-Speed Manual)
1st 2.722 3.230 3.230 3.230
2nd 1.468 1.900 1.900 2.105
3rd 0.975 1.269 1.360 1.458
4th 0.638 0.966 1.034 1.107
5th --- 0.714 0.787 0.848
Final Drive 4.357 4.266 4.400 4.400
Reverse 1.954 3.000 3.000 3.000
Body/Chassis
Model RS, LS, GS, SE Coupe RS, LS, GS, SE Sedan GS-R Coupe/Sedan Type R
Front Stabilizer Bar 22mm (94-99)
24mm (00-01) 22mm (94-99)
24mm (00-01) 24mm 24mm
Rear Stabilizer Bar 13mm 14mm 14mm 22mm
Front Brakes Ventilated, 10.3 in. disc type Ventilated, 11.1 in. disc type
Rear Brakes Solid, 9.4 in. disc type Solid, 10.2 in. disc type
Wheels 5.5jj x 14, steel or
6.0jj x 15, cast aluminum alloy 5.5jj x 14, steel or
6.0jj x 15, cast aluminum alloy 6.0jj x 15, cast aluminum alloy 6.0jj x 15 cast aluminum alloy
Tires Yokohama P195/60 R14 or
Michelin XGT V4 P195/55 R15 Yokohama P195/60 R14 or
Michelin XGT V4 P195/55 R15 Michelin XGT V4 P195/55 R15 Bridgestone Potenza RE010 P195/55 R15
Steering Rotary-valve, variable power-assisted rack-and-pinion
Turning Circle 34.8 ft. 35.4 ft. 34.8 / 35.4 ft. 34.8 ft.
Weight Distribution 64/36 62/38
Performance
Model RS, LS, GS, SE 4spd. Automatic RS, LS, GS, SE 5spd. Manual GS-R Type R
Acceleration (0-60mph) 8.5 sec. 7.6 sec. 7.2 sec. 6.5 sec.
1/4 mile run 16.8 sec. 16.1 sec. 15.5 sec. 14.7 sec.
Stopping distance (60-0mph) 143 ft. 116 ft.
Skidpad 0.76g 0.76g 0.80g 0.91g
Slalom (100 ft.) 57.5 mph 58.9 mph 62.8 mph 67.6 mph
Fuel Economy (City/Highway) 24/30 mpg 25/30 mpg 25/31 mpg 25/30 mpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bmaga123 »</TD></TR><TR><TD CLASS="quote">Is it alot more drastic when vtec kicks in then both the si and gs-r?</TD></TR></TABLE>
In short yes. You sound like you need to do a lot of reading up on these things. I would go through the FAQ's and read as many posts as possible. I think I read on the site for about 6 months before I signed up as a user. I'm not trying to be a dick but the only way to learn is to put yourself forward and do it. Good luck with the new car and please keep it safe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">
In short yes. You sound like you need to do a lot of reading up on these things. I would go through the FAQ's and read as many posts as possible. I think I read on the site for about 6 months before I signed up as a user. I'm not trying to be a dick but the only way to learn is to put yourself forward and do it. Good luck with the new car and please keep it safe.</TD></TR></TABLE>
Word!
Si and a R are not comparable.
Word!
I no lots about both cars and all the specs down to the tee. I just worded it wronf I guess. I basically just want to no the difference in feeling between the cars since I have never ridden in a Type R. I no they are way better but how much of a difference is there basically when vtec engages. I hate the dual stage manifold of the GS-R. The Si's motor seems better to me. I like the fact that the Type R has a single stage manifold. Jst want to experience comparisons. Thanks
Register your R on http://www.itrca.com..... This site will also give you tons of info on your new car..... Have fun and good luck with it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bmaga123 »</TD></TR><TR><TD CLASS="quote">I no lots about both cars and all the specs down to the tee. I just worded it wronf I guess. I basically just want to no the difference in feeling between the cars since I have never ridden in a Type R. I no they are way better but how much of a difference is there basically when vtec engages. I hate the dual stage manifold of the GS-R. The Si's motor seems better to me. I like the fact that the Type R has a single stage manifold. Jst want to experience comparisons. Thanks</TD></TR></TABLE>
You question makes more sense now..but I still suggest you wait till your new toy arrives, then tell us
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">Being that I've had both there is no compairison. It's like night and day. the R is much crisper in corners, much more raw feeling, faster, vtec "kicks" in harder and it's much more of a theft magnet.</TD></TR></TABLE>
THIS IS EXACTLY, WHAT I WAS GOING TO SAY. ON POINT.
HANDS- DOWN.
HANDS- DOWN.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 »</TD></TR><TR><TD CLASS="quote">You buy car be4 drive? I kno think that two smart. You shoore it good? Type R vtec kik hard like donkey punch.</TD></TR></TABLE>
Fixed that for you.
Fixed that for you.
yah..i also have driving both My Type R and a SI. And yah..there both two way different cars...I do love the way the SI's Vtec sounds..It really high pitch and loud. and a type R's Vtec is more of a deaper sound. Yes the Type R handle's very well and takes corners nice and is faster. no doubt..but there both two great cars.
Like people said before..Learn more about the car before buying it..
I've had the opportunity to drive an Si, which was my first love, an R, the second love, but she wasn't in the best condition, and now a GSR. The Si seemed like a high school car to me, seats weren't very comfortable, not as good of quality as Integras. The R was raw and big fun. The GSR compared to the Si is a nice car to cruise in. Comfortable leather, good ride (stock). Sound system could use a little help though, never bothered me in the R though.
For the record, My Si had intake, exhaust, suspension and 17" Volks, rough ride, loud. The R was stock but much for focused and handled better than the Si with suspension. The GSR is stock except for intake and will probably remain so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeftLaneB*tch »</TD></TR><TR><TD CLASS="quote">I just can't believe you bought the R without driving in it.</TD></TR></TABLE>
yah i remember before i bought my R..I took the car out and spanked it in Vtec before i handed over the cashflow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bmaga123 »</TD></TR><TR><TD CLASS="quote"> What I want to no is what does it feel like at vtec crossover in the type R </TD></TR></TABLE>
Type R's dont have Vtec
When i bought my car, i got to drive it around a townhouse block @ 5mph...:\ (No insurance, plated and lived DOWNTOWN Jungle of TORONTO!!! Arghh)
Luckily i was with my Uncle, hes 6'3 260lbs...
I simply told the dude, "I love the car, looks great, mint condition.. but you SURE and GUARENTEE when i hand the cash over it runs PERFECTLY GOOD?, because i don't **** around, so don't **** aruodn with me.." -in a jokingly manner of course.. -he replied, "YES yes, dont worry!"
Next day, gave him 19gs in cash and drove away.. thing ran better then my 02 RSX-S!
Its a 50/50 situation i guess.. i took my chances, and so did he..
lol.. i forgot to add, i won't forget the day i picked it up..one of the best days :D
I had a 1 hour trek bac home... and i drove thru downtown T.Dot in my new fresh R.. man.. I felt like GOD. hahah.. got on VTEC and my face just turned blush red. Like a little boy on christmas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stein »</TD></TR><TR><TD CLASS="quote">I've had the opportunity to drive an Si, which was my first love, an R, the second love, but she wasn't in the best condition, and now a GSR. The Si seemed like a high school car to me, seats weren't very comfortable, not as good of quality as Integras. The R was raw and big fun. The GSR compared to the Si is a nice car to cruise in. Comfortable leather, good ride (stock). Sound system could use a little help though, never bothered me in the R though.
For the record, My Si had intake, exhaust, suspension and 17" Volks, rough ride, loud. The R was stock but much for focused and handled better than the Si with suspension. The GSR is stock except for intake and will probably remain so.</TD></TR></TABLE>
Well, I love my SI (well, right now I "hate it"), but YAH. I have full GSR leather in there. I think it's comfy. I'm trying to get away from that. I like that raw ride. Owning an R is a constant headache.
I hope you are prepared.
HAHAHAHAHAHA..DAMMMMMMM RIGHT!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 »</TD></TR><TR><TD CLASS="quote">You buy car be4 drive? I kno think that two smart. You shoore it good? Type R vtec kik hard like donkey.</TD></TR></TABLE>
Chill out
I was Never in a Integra before I bought mine
Chill out
