B16A2 setup?
okay i have a 99 Si. i have a J's racing c.f. intake,CTR headers,Omni=power testpipe,Greddy Evo2 exhaust. i'm going to build my motor(all motor). my budget is around $3500. here it goes
Head:
Port and polish
Skunk 2 stage 2 cams
Skunk 2 cam gears
duyal valve springs
titainum retainers
Skunk 2 intake manifold
Skunk 2 throttle body
Fuel:
ADJ. fuel reg.
Walbro 255 fuel pump
P28 rechippd obd 1 ecu
obd2 to obd1 conversion harness
Apexi-v-afc CONTROLLER
bLOCK:
gsr B18 C1/5(itr)
stock crank (micro polishes and balanced)
stock gsr/itr rods
oem b16a/pr3 pistons with new oem rings
any suggestions? with these mods what WHp numbers will i be looking at?
thanks
David
Head:
Port and polish
Skunk 2 cam gears
duyal valve springs
titainum retainers
Fuel:
ADJ. fuel reg.
bLOCK:
gsr B18 C1/5(itr)
stock gsr/itr rods
thanks
David
i would not run the skunk2 springs/retainers...they break
Fuel:
ADJ. fuel reg.
if your going to use a p28 you can get it tuned...so you dont need a adj fuel reg or the apexi vafc....
bLOCK:
gsr B18 C1/5(itr)
stock gsr/itr rods
i would go with something other then stock rods/pistons if your going to go to all that trouble....
Fuel:
ADJ. fuel reg.
bLOCK:
gsr B18 C1/5(itr)
stock gsr/itr rods
AdrianArteaga98
20
Apr 17, 2017 06:54 PM
