code for a check engine light
Old Sep 6, 2005 | 05:34 AM
vtec-adykt's Avatar
Default code for a check engine light
i've pulled codes before on previously owned hondas, so im not a complete dumbass, but i recently purchased a 1989 crx dx. It has the stock d15b2 in it. but after about 6-7 minutes of driving, the check engine light comes on. Then i went to find the service connector to stick a jumper wire in it, and when i did, i turned the key to the last position, but no cel blinks. So my question is, is there a special way your supposed to pull the code on crx's or are all hondas the same?
Old Sep 6, 2005 | 05:39 AM
davens's Avatar
The "CEL blinks" you are looking for is a red LED on the actual ecu. If you pull up the passenger side footwell carpet you'll see a gold plate with a hole in it. The blinking LED should be visible through the hole. And there is no jumper plug required to read it.
Old Sep 6, 2005 | 06:07 AM
vtec-adykt's Avatar
Default Re: (davens)
so when i turn the key to the III position, the ecu red light will blink to tell what code it is?
Old Sep 6, 2005 | 08:46 AM
vtec-adykt's Avatar
Default Re: (vtec-adykt)
will the red light do the long and short flashes to distinguish the code?
Old Sep 6, 2005 | 09:12 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec-adykt &raquo;</TD></TR><TR><TD CLASS="quote">will the red light do the long and short flashes to distinguish the code?</TD></TR></TABLE>
on a DX with DX ECU there are no long flashes - all just short
Old Sep 6, 2005 | 09:19 AM
drdisco69's Avatar
Yep, just like the light in the dash otherwise would.
Old Sep 6, 2005 | 09:24 AM
spazz0nater's Avatar
Default Re: (drdisco69)
after you have gotten the blinks how do you fing out what code it is?
Old Sep 6, 2005 | 09:41 AM
vtec-adykt's Avatar
Default Re: (spazz0nater)
do the search option on here with whatever code number is usually what i do, but i have to figure mine out first.
Old Sep 6, 2005 | 09:47 AM
drdisco69's Avatar
FAQ much?
https://honda-tech.com/zerothread?id=468260
Old Sep 6, 2005 | 10:07 AM
vtec-adykt's Avatar
thanks guyz! i fugured out that it was a code 1 and 16 for a stock obd0 crx dx with a d15b2. it shows to be a faulty "primary" o2 sensor and a faulty fuel injection system. these motors run on only two fuel injectors, so it shouldn't be hard to fix. I want to keep this dpfi system for the meantime due to expensive gas prices. where should i start about fixing my problem?
M15
20
Aug 13, 2005 12:49 PM
type Gendy
Apr 21, 2003 04:48 PM
smithbling
Nov 19, 2002 12:26 PM
