WOAH MAJOR PROBLEm with my swap.. help please?
Old Sep 6, 2005 | 02:19 AM
Fugun's Avatar
Default WOAH MAJOR PROBLEm with my swap.. help please?
ok ive had my swap in for a little under a week now, and ive been driving, ive noticed my gas mileage is really CRAPPY
i drove 75 miles and it used half a tank of gas... does the b16a relaly eat that much gas? LOL
please help
peace
Old Sep 6, 2005 | 03:07 AM
2point3h22lude's Avatar
Default Re: WOAH MAJOR PROBLEm with my swap.. help please? (Fugun)
Find a way to figure out what your air/fuel ratio is, a wideband A/F ratio gauge is preferred, to see if you are running rich. If you are, then find a way to lean out your A/F ratio, like putting in a piggy back fuel management system, or reprogram your ECU by replacing the chip with one with a leaner A/F ratio. Or you could make sure that the fundamental fuel savings maintenance are done, like clean air filter, clean spark plugs, caps and rotors, etc.
Old Sep 6, 2005 | 06:05 AM
BoOstedEM1's Avatar
Go with a emanage..and a/f wideband.
Old Sep 6, 2005 | 06:37 AM
LShatchie's Avatar
Default Re: WOAH MAJOR PROBLEm with my swap.. help please? (BoOstedEM1)
I think you should atleast be getting 120 miles per half tank
Old Sep 6, 2005 | 07:32 AM
94CivicSi's Avatar
What ECU are you using?
Is the back of the car covered in black soot?
Old Sep 6, 2005 | 07:40 AM
mwieczorek43's Avatar
Default Re: (94CivicSi)
Are you throwing any CEL's
Old Sep 6, 2005 | 10:28 PM
Fugun's Avatar
Default Re: (mwieczorek43)
thank you for all your replies they are all greatly useful,
as far as CELs, yes i am, its off when i start the car and after i drive it for a lil bit it turns on.
the setup im using is as follows
its a 97 ex, with
92 b16a
and the ecu *shrugs* its labled 91 the obd1 plugs fit though
im using my obd2 wiring harness, with a obd2 -> 0bd1 harness
i tried jumpping the CEL from the plug, it wont go, the obd2 code reader wont read i dont know how else to get that lil fricker to flash :-\ or tell me anything other than its on...
as far as black spot on the back of my car, negative, i cant really tell the car is black, not that i noticed though, but it does smell funky :-P
ill try use a wideband and try figure out if im rich ornot, but OMFG the gas prices are killing me :-P
thanks for all your help
hope this added information helps you guys help me
Old Sep 7, 2005 | 11:19 AM
ekgcool's Avatar
Default Re: (Fugun)
There "should" be a serial number on the side of the ecu (computer). For obd1 you have a few options, but look at the center 3 digits. There "should" be at least one of these P28, P30, P72, P73, P75. Only the p30-72-73's are DOHC VTEC ecu's. If you have any other 3 digit serial then the ecu is probably chipped and can have a super aggressive fuel curve. If not then be sure the O2 sensor is hooked up right. Also be sure to check the MAP sensor. If these check out then look toward the fuel pressure regulator (which may remain open (full presure)) or a basic tune up.
Old Sep 7, 2005 | 12:10 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (tekracer)
Does a bad o2 sensor effect gas mileage?
Old Sep 7, 2005 | 12:53 PM
Soccerking3000's Avatar
Default Re: (EJ8VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Does a bad o2 sensor effect gas mileage?</TD></TR></TABLE>
lol just a little bit..
Old Sep 7, 2005 | 01:06 PM
Relic1's Avatar
much like riding on the bump stops effects ride quality.
Old Sep 7, 2005 | 05:33 PM
Fugun's Avatar
Default Re: (Relic1)
thanks for all your help, do you think timing would have a big effect on this as well too ?
Old Sep 8, 2005 | 12:18 PM
Default Re: (Fugun)
lol yes
Old Sep 12, 2005 | 12:36 AM
Fugun's Avatar
Default Re: (Soccerking3000)
okay update for you all
i still dont understand the CEL, i can start the car and ohh no CEL, but after driving a bit it turns on...
i shot the timing, its dead on, so its not the timing, so tomarrow im going to try a diffrent ECU, and open mine, check for any chip
because its running very rich
i had a friend follow me, when i dump it, it pours smoke, and you can smell it
hopefully its just the ECU tripping out
Old Sep 12, 2005 | 09:52 AM
Turbo(less)DB8's Avatar
Default Re: (Fugun)
this may be because of a poor quality obd2-1 harness. it sounds like the ecu is resting itself when the car is turned off. this would lead one to believe the it's constant feed is running switched (w/ the ign)
Old Sep 13, 2005 | 01:23 AM
Fugun's Avatar
Default Re: (TurboDB8)
here comes another update
i fixed a vacuum leak and wahlah idle is great, mileage is good
also discovered a motoer mount is no good so i have that to fix
but mileage is good now
thsx for ur help
jorge89
Jun 25, 2008 09:34 AM
slickslvr01
Honda Civic (2001 - 2005)
12
May 27, 2008 08:16 AM
90jdmcrxdude
May 5, 2006 10:20 PM
kingpen
Aug 31, 2002 09:17 PM
Jesse H
Dec 19, 2001 02:07 PM
