engine coolant sensor
Old Sep 5, 2005 | 09:18 PM
eskimo_usd's Avatar
Default engine coolant sensor
where is the engine coolant sensor located, and how do i fix it if the CEL keeps coming up and thats the only code it brings up. thanks to anyone that replys to this.
Old Sep 5, 2005 | 09:19 PM
RaysBoomBoomLude's Avatar
Default Re: engine coolant sensor (eskimo_usd)
Its on the head, right below the Dizzy. its ONE wire plug.
Hows the temp reading on your cluster?
Old Sep 5, 2005 | 10:52 PM
RA122324's Avatar
The coolant temp sensor is on the back of the block near the oil filter. It's connection is two gold prongs. Don't bother going to the dealer to find one. Try a junk yard.
Oh yeah, it's a bitch to get off so don't break it.
Old Sep 5, 2005 | 10:57 PM
RCautoworks's Avatar
Default Re: engine coolant sensor (LaFawnduh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaFawnduh &raquo;</TD></TR><TR><TD CLASS="quote">Its on the head, right below the Dizzy. its ONE wire plug.
Hows the temp reading on your cluster?</TD></TR></TABLE>
Thats for the gauge cluster, nothing to do with the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knwldge54 &raquo;</TD></TR><TR><TD CLASS="quote">The coolant temp sensor is on the back of the block near the oil filter. It's connection is two gold prongs. Don't bother going to the dealer to find one. Try a junk yard.
Oh yeah, it's a bitch to get off so don't break it.</TD></TR></TABLE>
Thats the fan switch
Taken from 7PSI CRX
1 for the radiator fan On/Off - LIGHT BLUE
1 for the temp gauge on the dash - LIME GREEN
1 for the ECU - RED
Old Sep 5, 2005 | 11:21 PM
Twilight's Avatar
Default Re: engine coolant sensor (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knwldge54 &raquo;</TD></TR><TR><TD CLASS="quote">Don't bother going to the dealer to find one. Try a junk yard.
That reminds me of a one time. I accidentally snapped the 2 wire coolant sensor (ECU one) when removing the head. And in the same time when i picked OEM honda gaskets up. I asked about the sensor, lol it was 78€ (ab. $83) for a small sensor.
Then i bought another head for spare, and got all the sensors with it. Even the old one still worked.
Old Sep 6, 2005 | 03:07 PM
eskimo_usd's Avatar
Default Re: engine coolant sensor (Twilight)
THE TEMP GAUGE ON THE CLUSTER IS FINE. I JUST KEEP GETTING THE CODE 6 AND I DONT KNOW WHY. BY THE WAY EVERYTHING IS CONNECTED.
Old Sep 6, 2005 | 03:37 PM
g-ride-si's Avatar
Im gonna say this before anyone else take caps lock off. Now I had the same problem after my b18a swap it all looked good but right at the plug there was a broken wire i cut it back stripped it and stuck another one on. no more cel.
Old Sep 7, 2005 | 05:07 PM
eskimo_usd's Avatar
Default Re: (g-ride-si)
alright thanks man, im gonna have to check that out.
Old Sep 8, 2005 | 09:45 PM
eskimo_usd's Avatar
Default Re: (eskimo_usd)
alright just to let everyone know there are no fucked up wires. do you guys think i should just buy a new sensor?
Old Sep 8, 2005 | 10:10 PM
How do you know all the wires are ok, did you test them ? You can test the sensor with a dvom and it will tell you if it is fine or not.
Old Sep 8, 2005 | 10:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo_usd &raquo;</TD></TR><TR><TD CLASS="quote">alright just to let everyone know there are no fucked up wires. do you guys think i should just buy a new sensor?</TD></TR></TABLE>
did you already replace the sensor???
Old Sep 9, 2005 | 07:47 PM
eskimo_usd's Avatar
Default Re: (LaFawnduh)
yeah i replaced the sensor and everything is back to normal. thanks for the help.
JSPECHB
Nov 14, 2014 09:30 AM
93del
Dec 19, 2010 09:49 AM
racer_X_123
Sep 13, 2005 03:05 PM
SOFLSOL
Sep 3, 2003 03:59 PM
