So i'm startin to look for a Type-S
Old Sep 5, 2005 | 06:34 PM
StupidSlowRSX's Avatar
Default So i'm startin to look for a Type-S
Well, until today I always thought a Type-S would be completely out of my leauge as far as money was concerned. I found an 02 Type-S with around 60k miles with a flawless interrier. They only wanted 16,950. I would be droppin around 4k down on it so I figure monthly payments should rape me too much.
mmk, heres my questions.. Is there anything I should be looking for that maybe an 02 type S would be notrious for? Rust? damage locations? etc etc. I know what to listen for as far as the motor is concerend, I'm just a little shady on anything else.
Ahh, one more question.. As of now I have a CRX w/ a B16A blah blah mid 14's 1/4... SUcky *** highway car.. 85 mph is 5k in 5th gear.
How are Type S on the highway for cruising on a 30-40 mile trip? What RPM is 80-85 in 6th gear? Is there a fuel cutoff? What gasmileage do you get on highway and city?
Thanks for any replies guys
Old Sep 5, 2005 | 06:38 PM
GradyDC5's Avatar
On the highway it should be around 4 thousand in 80... I can't remember i'm usually cruise locked at 60 to work. I traded a 01 s2k for an 02 Type-S, and I have not regreted it at all. Sure it's not as fast, but it's a great daily driver.
Recently took a trip to Columbia,SC from Memphis,Tn and ended up with 36 hwy.
Old Sep 6, 2005 | 11:53 AM
Default Re: (ReallySlowEg)
Thanks.. anyone else?
Old Sep 6, 2005 | 12:06 PM
HitEm'Up's Avatar
Default Re: (StupidSlowCRX)
Just bought a 06 type-s
Old Sep 6, 2005 | 12:52 PM
DC5AM's Avatar
Default Re: So i'm startin to look for a Type-S (StupidSlowCRX)
02-04 models have a famous transmission problem. There is a 2nd gear grinding issue and a gear popping issue when shifting to 3rd. Someone correct me if I'm wrong.
Old Sep 6, 2005 | 01:11 PM
HitEm'Up's Avatar
Default Re: So i'm startin to look for a Type-S (coolguy650)
I thought i heard of a few that have had some issues also
Old Sep 6, 2005 | 01:31 PM
BoBoChan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">How are Type S on the highway for cruising on a 30-40 mile trip? What RPM is 80-85 in 6th gear? Is there a fuel cutoff? What gasmileage do you get on highway and city?</TD></TR></TABLE>
80-85 in 6th gear is around 3.5k
the type-s is a bumpy ride, take a 2nd look at the roads around you b4 buying one, the bumpiness can give you a headache but for me its not bad at all, as far as gas mileage, im calculating mine right now, so yahs :/
edit: i have not yet experienced the "2nd gear grind" that ive heard of, but my 3rd gear does pop out occasionally, like... once ever 5 hours of drivin, but i quickly solved that by takin extra time and making sure im putting it 3rd strong
Old Sep 6, 2005 | 01:34 PM
Mr_Si-R's Avatar
ive also heard the the syncros will go out to making it really painful to hear it shift from 2nd to 3rd
Old Sep 6, 2005 | 03:05 PM
Default Re: (Mr_Si-R)
hhhahahaah a bumpy ride eh???
at the moment im rolling around with AGX shocks and Neuspeed race springs on my CRX... Thats... a bumpy ride.
So.. Notrious tranny problems eh?? I think I remember reading a while back that the dealer would fix this problem.. Is that true?
Old Sep 6, 2005 | 03:43 PM
BoBoChan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">So.. Notrious tranny problems eh?? I think I remember reading a while back that the dealer would fix this problem.. Is that true?</TD></TR></TABLE>
it really depends on how ur dealer is, they could play it off and try to find as many excuses as possible or they could agree and fix it, i havent taken mine in yet, but i have a feelin they are lazy dicks
Old Sep 6, 2005 | 05:03 PM
Default Re: (BoBoChan)
good thing im an annoying bastard
Old Sep 7, 2005 | 09:45 PM
GradyDC5's Avatar
Default Re: So i'm startin to look for a Type-S (BoBoChan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">
edit: i have not yet experienced the "2nd gear grind" that ive heard of, but my 3rd gear does pop out occasionally, like... once ever 5 hours of drivin, but i quickly solved that by takin extra time and making sure im putting it 3rd strong</TD></TR></TABLE>
A bumpy ride ? It's far from bumpy i'd say, and I've never had any tranny problems out of mine. I guess since I don't acutally drive mine hard at all. Cruising to work doesn't require me to "get on it" .
Old Sep 8, 2005 | 01:16 PM
Honda.F1's Avatar
Default Re: So i'm startin to look for a Type-S (*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolguy650 &raquo;</TD></TR><TR><TD CLASS="quote">02-04 models have a famous transmission problem. There is a 2nd gear grinding issue and a gear popping issue when shifting to 3rd. Someone correct me if I'm wrong.</TD></TR></TABLE>
what he said. I was seriously thinking about getting a RSX until I read about all the tranny problems people are having, apparently with 05s also.
http://forums.clubrsx.com/show...27026
sounds like the dealers are not willing to fix it either, saying they can't replicate the problem . (typical dealer scam for trying to get out of fixing a car)
just google search RSX gear grinds or RSX problems.
sounds like a great car otherwise
Old Sep 8, 2005 | 03:23 PM
littlej72's Avatar
Default Re: So i'm startin to look for a Type-S (Honda.F1)
If you think of and describle the dealer as lazy dicks I assure you, you wont be getting much from them outside of warranty especially if you approach tactfully and get a good tech and don't beat the **** out of your car(they can tell) you will get helped just fine. Treat people as you want to be treated, it goes a long way. It's like anything else though, how many people do you work with at your job that are "lazy di..s" is it you? well its that way everywhere.
Old Sep 10, 2005 | 10:46 AM
xsoofreshx's Avatar
ooo so im not the only one lol cuz my 2nd gear doesnt grind but its not goin in smooth sometimes and my 3rd gear does pop out every now and then . its a **** ! but i still love it
Old Sep 12, 2005 | 11:54 PM
DeltaClothingCo's Avatar
Default Re: So i'm startin to look for a Type-S (xsoofreshx)
i got an 02 type s 90mph is 4k gas mileage i dont know cause i dont drive regularly but i get around 300 miles to a tank of gas. the ride is smooth as hell (its at stock height for the moment). Ive never experienced anything wrong with the tranny and im at 55k. The only thing i notice about mine is that if youre not at a complete stop while putting it in reverse it grinds pretty good. all around its an awesome car that you will be alot happier with over the base model. I drove mine from tucson to san fran and it was smooth as hell.
Old Sep 13, 2005 | 12:16 PM
BlackSage's Avatar
If you are coming from a crx thats dropped the ride will be great. I have an 02 and I havent had ANY tranny issues since 09/01 when I bought it.
Old Sep 13, 2005 | 12:57 PM
acurate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBoChan &raquo;</TD></TR><TR><TD CLASS="quote">80-85 in 6th gear is around 3.5k</TD></TR></TABLE>
just to add on... in an 05 it's 4k... type-r final drive.
20 mph / 2ng gear = 3k rpm
30 mph / 3rd gear = 3k rpm
40 mph / 4th gear = 3k rpm
50 mph / 5th gear = 3k rpm
60 mph / 6th gear = 3k rpm
Old Sep 13, 2005 | 03:37 PM
nadaclue's Avatar
I'd keep looking for better deals. I love my Type-S but am selling it to downsize my debt. Mine's an '03 with 29k miles and I'm asking $17k including 18" wheels/tires, coilovers and an intake. And I've only had 2 people come look at it in the past month, even though I think it's a killer deal.
And yes, the Type-S is worth every penny. So keep looking, there are deals to be had.
Old Sep 13, 2005 | 05:10 PM
M1K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">Well, until today I always thought a Type-S would be completely out of my leauge as far as money was concerned. I found an 02 Type-S with around 60k miles with a flawless interrier. They only wanted 16,950. I would be droppin around 4k down on it so I figure monthly payments should rape me too much.
is it this one?
http://autotrader.com/fyc/vdp....st=23
if so, im gona get it before you
probably not but good luck with her if it is
wait, you said flawless interior? i see no interior..
would honda/acura cover the tranny problem or if the cars past warranty would you be fucked?
Modified by M1K3 at 9:22 PM 9/13/2005
Old Sep 15, 2005 | 05:24 AM
chairlifttypes's Avatar
Default Re: So i'm startin to look for a Type-S (M1K3)
he said hed be making monthly payments, that usually means its a dealer not a private seller
Old Sep 15, 2005 | 12:12 PM
MINUS_the_'s Avatar
Default Re: So i'm startin to look for a Type-S (chairlifttypes)
check my sig
Old Sep 15, 2005 | 03:34 PM
Default Re: So i'm startin to look for a Type-S (MINUS_the_)
eh.. The one I want is blue.. The dark blue or the new orange they come in. Its a 2005 only color I think.. Not tryin to knock your car though.. Thats a nice *** car for 16k. If it was blue and had black leather i'd be all over it ;]
Old Sep 16, 2005 | 04:49 AM
TypeSKid's Avatar
the tranny problems where for the first so many 02's i think
Old Sep 16, 2005 | 01:08 PM
MINUS_the_'s Avatar
trust me i wish i had black interior
Billy Elliot
14
Sep 1, 2011 11:12 AM
lude98SH
Mar 24, 2011 12:05 PM
JOMO_
Jul 4, 2003 01:18 PM
drumsy
20
Jun 28, 2002 10:04 PM
GS-R Jay
17
May 25, 2002 11:12 AM
