b16 vs itr intake manifold? which has more area under the curve?
Old Sep 5, 2005 | 06:14 PM
an2ny888's Avatar
Default b16 vs itr intake manifold? which has more area under the curve?
just read a book with dyno charts showing that the b16 intake manifold was better than the itr manifold on a b16 and a b20 throughout the rpm range, with the itr manifold showing gains only from 8000rpm up. so for a street motor, it seems that the b16 manifold is hard to beat. anybody care to chime in?
Old Sep 6, 2005 | 12:34 AM
dragonz04's Avatar
Default Re: b16 vs itr intake manifold? which has more area under the curve? (an2ny888)
yes that is true, the p30 manifold or the b16 from a del sol, makes more power under 8000 rpm. so it's either you want peak numbers w/ the itr manifold or more power under the curve.... w/ a p30
Old Sep 6, 2005 | 05:10 PM
an2ny888's Avatar
Default Re: b16 vs itr intake manifold? which has more area under the curve? (dragonz04)
just wondering if this applies to a b18c as well
Old Sep 7, 2005 | 03:53 PM
Cory man's Avatar
Im wondering if there are any comparos between the 1g B16 intake manifolds and the p30's? Any dyno #'s etc?? Ive always been under the impression that the 1g B16 I.M were a bottleneck. Correct me if I'm wrong.
BTW a b16 p30 manifold wont bolt up to a gsr head.
Old Sep 7, 2005 | 04:52 PM
an2ny888's Avatar
Default Re: b16 vs itr intake manifold? which has more area under the curve? (Cory man)
i meant a b18c-r engine. so the first gen b16 isn't a p30? what is stamped on it?
Old Sep 8, 2005 | 09:40 AM
Cory man's Avatar
I did some searching and didnt find anything worth mentioning. Bump this up for a definite answer.
Old Sep 25, 2005 | 01:05 PM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">i meant a b18c-r engine. so the first gen b16 isn't a p30? what is stamped on it?</TD></TR></TABLE>Pr3 is a first gen jdm b16a
Old Sep 26, 2005 | 11:38 AM
turbo boost's Avatar
Default Re: b16 vs itr intake manifold? which has more area under the curve? (HondaCivicSiR1)
yea id also like to no if there is any power diff from useing a pr3 I.M. and a p30I.M. ..any graphs anybody ???
Old Sep 27, 2005 | 01:21 AM
Default Re: b16 vs itr intake manifold? which has more area under the curve? (snowbunny)
anybody?
dutchman5
Texas -OK -LA (Sales)
Oct 29, 2010 12:50 PM
mrbsponge
Sep 26, 2005 10:32 PM
Deetz
Dec 23, 2004 09:59 AM
garylythgoe
Sep 30, 2004 04:41 PM
