vtec not working... at vtec engagement, it falls on its face
Old Sep 5, 2005 | 06:03 PM
ensracer's Avatar
Default vtec not working... at vtec engagement, it falls on its face
its a 88 hatch with a d15b, using a p28 ecu. everything works fine but the vtec does not work, it has the original fuel pump from the original motor that was dpfi, maybe i need a fuel pump? let me know what it could be. vtec engages at 5k and as soon as that rpm is reached the motor just cuts of and goes of an on...
Old Sep 8, 2005 | 02:03 PM
killa rex's Avatar
Default Re: vtec not working... at vtec engagement, it falls on its face (ensracer)
d15b?? they shouldn't have vtec...i thought d16y7-8 are the vtec motors??
Old Sep 8, 2005 | 02:10 PM
ensracer's Avatar
jdm motor...
Old Sep 15, 2005 | 09:25 PM
killa rex's Avatar
Default Re: (ensracer)
oh ok
Old Sep 15, 2005 | 10:15 PM
onepoint6i's Avatar
check your grounds
Any codes?
Run 12 volts to your solenoid to see if vtec is activating
Hows your oil pressure?
Is vtec wired right?
Your oe fuel pump is sufficient, thats not your problem.
Hows your fuel pressure?
do you have a obd 1 distributor?
Hows your cam timing?
dsmslyr55
Jul 29, 2010 08:17 AM
roadracer321
Jan 9, 2008 05:29 AM
speedunlimited
Sep 16, 2004 08:08 AM
gethighonsi
11
Jun 20, 2003 06:48 AM
vspec12
Nov 5, 2001 05:25 AM
