B16 into a 91 CRX HF Axle/GSR Trans question
Old Sep 5, 2005 | 05:30 PM
CRXB16T's Avatar
Default B16 into a 91 CRX HF Axle/GSR Trans question
I used the search function and could not find concise answers to my questions.
So here is my dilemma. I am swapping a B16 from my wrecked 89 Civic DX Hatch into my 91 CRX HF. The Y1 trans in the Civic was whooped so I picked up a like new GSR Hydro Trans from the dealer with 12,000 miles on it. The only thing I had to do was swap the speedometer gear from the Y1 into the GSR Trans and get a hydraulic to cable conversion kit from hasport.
The B16 was in a 89 Civic DX Hatch with a Y1 trans, I *think* it had 93 Integra axles and the intermediate shaft has SK7 stamped on it.
Now I want to swap the B16 into my 91 CRX HF using a 94 GSR Trans with a Quaife LSD. I bought the Hasport EFB2 Hydro to Cable Conversion kit, 93 Integra axles. Will this combination work?
So my questions are:
1. Will a 94 GSR Hydro Trans work with 93 Acura Integra axles in a 91 CRX HF?
2. Will the speedometer drive gear in the Y1 swap into the GSR trans?
3. Will the SK7 intermediate shaft work with this combination or do I need a different intermediate shaft?
Any Help would be greatly appreciated.
Old Sep 5, 2005 | 07:57 PM
Crx Jimmy's Avatar
Default Re: B16 into a 91 CRX HF Axle/GSR Trans question (CRXB16T)
yes everything you posted will work fine , axles, intmed shaft, and speedo gear are fine, you will need to put your dx spindles on or si or da ones to make the axles fit into the hub
Gasoline Fumes
43
Jul 6, 2012 01:07 PM
slowcrx954
Jul 14, 2007 09:02 PM
RACING INTEGRATION
Mar 3, 2006 08:09 PM
crix180
Jun 29, 2003 12:55 PM
hybridrexsir
Apr 10, 2003 02:46 PM
