Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Good Pedals Needed to perform Heel/Toe
Old Sep 5, 2005 | 04:25 PM
Power Rev Racing's Avatar
Default Good Pedals Needed to perform Heel/Toe
I went to HPDE for my first time yesterday. I did good besides the fact that i need to learn to do Heel/Toe better. But what was really holding me back is that my 91 civic hB, the gas and brake pedals are spaced to far apart. So i guess i need to buy some good pedals to help me execute better. What pedals are you peeps running, and where did you get them from?
Old Sep 5, 2005 | 04:29 PM
gotocrx's Avatar
Default Re: Good Pedals Needed to perform Heel/Toe (Power Rev Racing)
Try experimenting with the position of your foot. You should be able to do it with the stock honda pedals. Since I don't use aftermarket pedals, I can't point you in the right direction.
Old Sep 5, 2005 | 04:50 PM
ewaugh's Avatar
Default Re: Good Pedals Needed to perform Heel/Toe (gotocrx)
I've never had a problem reaching over either, but then I wear a 12/13 shoe.
Old Sep 5, 2005 | 04:58 PM
splitime's Avatar
Default Re: Good Pedals Needed to perform Heel/Toe (ewaugh)
You could bend one of the pedals a little. I use stock pedals and heel/toe in my 92 and 91 civic, i have a size 9 shoe. No issues with heel/toe.
Old Sep 5, 2005 | 05:00 PM
stevel's Avatar
shouldn't need new pedals. Stock are just fine. You just need to practice it more. Be careful doing it on the street though, try and save it for empty parking lots.
s
Old Sep 5, 2005 | 06:29 PM
ohjolt2's Avatar
I think i am just going to make some out of 1/4 inch think aluminum plate and bolt them thought the stock pedal. That way i can shape them how ever i like them and adjusting the spacing and everything. Figure some skateboard grip tape should make them good. If that dosent work i might dill them out and put a grid of small screws in them.
Old Sep 5, 2005 | 07:53 PM
1GreyTeg's Avatar
Mine look old now in comparison but do simplify heel-toe:
Old Sep 5, 2005 | 08:16 PM
Default Re: Good Pedals Needed to perform Heel/Toe (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Mine look old now in comparison but do simplify heel-toe:
Those are nice. Where did u get those from?
Old Sep 5, 2005 | 08:39 PM
WRXRacer111's Avatar
LTB Motorsports sells a Sparco Race pedal for 25 bucks. I just installed a set of these on a friend's car. You have to drill through the stock pedals to mount them, but they're grippy and wide and cheap. Plus the vendor ships stuff in a big big hurry!
Old Sep 5, 2005 | 11:42 PM
Tyson's Avatar
Default Re: Good Pedals Needed to perform Heel/Toe (WRXRacer111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WRXRacer111 &raquo;</TD></TR><TR><TD CLASS="quote">LTB Motorsports sells a Sparco Race pedal for 25 bucks. I just installed a set of these on a friend's car. You have to drill through the stock pedals to mount them, but they're grippy and wide and cheap. Plus the vendor ships stuff in a big big hurry!</TD></TR></TABLE>
yeah, i bought this. all i needed really was the throttle pedal piece, which has the extra area at the bottom to "bring" the pedal closer. i suppose a piece of steel could be more cheaply added (screwed, welded) in, but $25 aint too expensive. i certainly wouldnt go off and spend anything more on any other aftermarket pedal set.
Old Sep 6, 2005 | 07:50 AM
Default Re: Good Pedals Needed to perform Heel/Toe (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, i bought this. all i needed really was the throttle pedal piece, which has the extra area at the bottom to "bring" the pedal closer..</TD></TR></TABLE>
Thats all I really need to is the Throttle pedal. But like you said $25 is not bad. So i am just going to buy that set.
Old Sep 6, 2005 | 08:26 AM
FlyZlow's Avatar
Default Re: Good Pedals Needed to perform Heel/Toe (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">shouldn't need new pedals. Stock are just fine. You just need to practice it more. Be careful doing it on the street though, try and save it for empty parking lots.
s</TD></TR></TABLE>
I really liked the Sparco pedals I had in my CRX. They made heel/toe a breeze even w/ my narrow size 9's. I drove the new car for the first time this weekend and it had a stock gas pedal. I could still heel/toe, but it required much more thought and coordination. IMO, it's worth getting a good set of pedals so that it doesn't take any thought away from the other things you're doing (braking/turning).
- Scott
Old Sep 6, 2005 | 08:57 AM
JDM Factor's Avatar
I just used grip tape on all the pedals. Even though it does hurt if you walk in them for a day...you might want to get a size smaller shoe size, it makes all the difference in pedal feel.
unrealwrc
25
Nov 3, 2008 03:42 PM
The Internet Tough Guy
46
Oct 20, 2003 09:36 PM
brady
11
May 3, 2003 01:19 PM
robbin
12
Mar 24, 2002 04:46 PM
Ken Tankerous
Nov 5, 2001 09:13 PM
