Car Amp inside the house
Old Sep 5, 2005 | 03:31 PM
EkLanta's Avatar
Default Car Amp inside the house
Is there anyway a Car amp can get power inside the house. Like a
adapter to plug in the wall so i can run subs inside the house for the computer?
Old Sep 5, 2005 | 03:32 PM
mrdeadman's Avatar
They let me pick
Default Re: Car Amp inside the house (Na Beast)
use a car battery
Old Sep 5, 2005 | 03:50 PM
EkLanta's Avatar
Default Re: Car Amp inside the house (mrdeadman)
yea i seen some people do that..But can u get like a adapter to plug in the wall socket or somthing?
Old Sep 6, 2005 | 06:04 AM
B18C_EJ8's Avatar
You need to take into consideration how many amps the unit draws when you choose your power supply... I don't know much about computer power supplies but I doubt they put out the 20 or 30 amps the amplifier needs at peak current draw...
You'd be better off getting a regulated power supply rated at 20 or 30 amps....
Old Sep 6, 2005 | 01:42 PM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">You need to take into consideration how many amps the unit draws when you choose your power supply... I don't know much about computer power supplies but I doubt they put out the 20 or 30 amps the amplifier needs at peak current draw...
You'd be better off getting a regulated power supply rated at 20 or 30 amps....</TD></TR></TABLE> Ditto that, a computers power supply is not big enough, the cheapest way to go is get a small batt. charger and a batt., a regulated power supply big enough to run an amp is not cheap Although there are some deals on eBay 94
Old Sep 6, 2005 | 04:16 PM
xomp's Avatar
the power supply i run on my computer right now is a 550w "sparkle" power supply. it's rated at 36a on the 12v. You can find other brands that are similarly priced that have that kind of output (mine was $100).
from there on (600w or higher) the price sort of goes up exponentially.
of course u cant just go around picking up any ol' $20 generic "550w" power supply if u plan on running that amperage.
Old Sep 6, 2005 | 05:49 PM
mikedd_87's Avatar
http://www.ramseyelectronics.c...32LAB
or something similar to that, thats prolly ur cheapest option, unless you want a digital display, that will run about $250 if you want digital display.
Old Sep 6, 2005 | 06:17 PM
EkLanta's Avatar
Default Re: (mikedd_87)
thank u
Old Sep 6, 2005 | 09:31 PM
SCIVIC94's Avatar
Default Re: (Na Beast)
HOP ON EBAY AND LOOK UP PYRAMID POWER SUPPLIES.I AM USING THE MODEL PS-52KX.I PAID ABOUT 165 SHIPPED.IT ADJUSTABLE VOLTAGE FROM 12V-15V AND IS RATED TO PUSH 42 AMPS CONTINUOS /52 AMPS PEAK.I HAVE IT FOR SIX MONTHES AND NEVER HAD A PROBLEM
Old Sep 7, 2005 | 10:38 PM
tyro's Avatar
Default Re: (SCIVIC94)
Astron makes some seriously heavy-duty 12v supplies too.
Being realistic, for the price of a large power supply, you could get a really nice set of computer speakers.
Old Sep 8, 2005 | 07:25 AM
nsxxtreme's Avatar
Default Re: (tyro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyro &raquo;</TD></TR><TR><TD CLASS="quote">Being realistic, for the price of a large power supply, you could get a really nice set of computer speakers.</TD></TR></TABLE>
Exactly!
The only way it makes sense if your not trying to spend any money is to use a car battery and charger, if you already have one.
fryman
Audio / Security / Video
Jun 11, 2008 05:41 AM
aznwash3wboi
Dec 24, 2005 09:18 AM
GroundZer0 336
Aug 14, 2003 06:49 PM
ilikemyaccord
May 27, 2003 01:51 PM
Dr Pooface
37
Jun 5, 2002 08:02 PM
