Time to replace my Fidanza's friction surface?
how many miles do you have on your flywheel? i got almost 40k on mine, so i hope you got much more than that.. whats the reason for pulling it in the first place?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">how many miles do you have on your flywheel? i got almost 40k on mine, so i hope you got much more than that.. ?</TD></TR></TABLE>
I have about 40,000ish kms on it, with 15ish track dayus and 20ish drag passes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">whats the reason for pulling it in the first place?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1362080
i am not 100% sure when the correct time is to replace them but they are relatively inexpensive - expect to pay about $85 shipped for one from experience.
Take it to a machine shop. They will use a machinist's straight edge and a lathe to see if the flywheel is out of balance. I was able to take a hair bit of material off the flywheel last time I took it off w/o replacing the friction surface...as long as they can keep the correct step size you dont need to replace.
Ch33se
Mar 3, 2004 11:49 PM
