TX: DOHC ZC wont pass emissions HELP
thought I'd post this here since the ZC is more popular in the EF chasis.
Thanks for any help I can get
Vic
my thread in the 92+ Civic section:https://honda-tech.com/zerothread?id=1361903
Vic
[QUOTE=integraduo]thought I'd post this here since the ZC is more popular in the EF chasis.
Vic
my thread in the 92+ Civic section:https://honda-tech.com/zerothread?id=1361903[/QUOTE
whoa, I didnt know Dallas was was doing the emissions test. I just moved from killeen ttexas and they always did the eyeball check, you know, just make sure your tail pipes were on type stuff
Vic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redryder »</TD></TR><TR><TD CLASS="quote">whoa, I didnt know Dallas was was doing the emissions test. I just moved from killeen ttexas and they always did the eyeball check, you know, just make sure your tail pipes were on type stuff</TD></TR></TABLE>
yeah they've been doing it a while..there are some counties that don't reqire a smog check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theharlequin »</TD></TR><TR><TD CLASS="quote">http://www.gutterslide.com/fou....html
its worth a try</TD></TR></TABLE> I"m going to give those suggestions a try...THANKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFcivicHB »</TD></TR><TR><TD CLASS="quote">Is it OBD-I? If it is you won't always get a code for the O2 sensor unless it doesn't work at all.</TD></TR></TABLE> it is OBD1, I have a new O2 I'm gonna swap tomorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TH33G4MON3 »</TD></TR><TR><TD CLASS="quote">its not going to either... I had a dohc zc... its jdm it won't pass... get a friend to do it or meet someone who works at a station</TD></TR></TABLE> I've gotten a ZC to pass before, but it was a PITA.
Thanks everyone...
Vic
Thanks everyone...
Vic
What kind of ecu are you using?
Is there a obd-1 ZC ecu?
The gutterslide suggestions are good but the proper fuel and timing maps on the ecu are going to dictate whether you are rich or lean.
If you're ecu is dumping too much fuel, most anything you would normally try to improve emissions is going to be undone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens »</TD></TR><TR><TD CLASS="quote">What kind of ecu are you using?
If you're ecu is dumping too much fuel, most anything you would normally try to improve emissions is going to be undone.</TD></TR></TABLE>
Well, I bought the car w/ the ZC w/ intentions to drop a d16z6/y8. but in order to title the car I need to get it inspected first. So far, it's an OBD 1 stock DX ecu, no mods that I can tell, Si tranny, header, stock replacement put on Sat, 2.25 exhaust, gonna replace the O2 tomorrow. Looks like the timing is set at stock, I thought about advancing it, but then Id be lean wouldn't I? If I retard it I may not pass HC or CO....I just need this thing to pass so I can get the title transfered, then I'll get the swap done....I only have 10 days to get it smogged.
Thanks for any help.
I think you need to do some research on title transfers.
What happens when people sell a nonrunning car or just a rolling chassis?
The title transfer still happens but there was no smog test because there was no running engine to test, right? If that ZC was "broken"...
Or maybe take possession with a bill of sale and start the z6/y8 swap...when its finished, do the smog/title transfer.
Have you thought about getting a chipped ecu? People do the p28 for pretty cheap these days.
The ZC owners typically use a PM6 program to pass emissions and than a PG7 or PM7 for their regular driving.
So get a PM6 map and put it in the P28. When you pass, change to a PG7 or PM7. I did something similar to this on my old mini-me. I put a P28 fuel/timing map in my PM6 custom .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens »</TD></TR><TR><TD CLASS="quote">What happens when people sell a nonrunning car or just a rolling chassis? The title transfer still happens but there was no smog test because there was no running engine to test, right? If that ZC was "broken"...
So get a PM6 map and put it in the P28. When you pass, change to a PG7 or PM7. I did something similar to this on my old mini-me. I put a P28 fuel/timing map in my PM6 custom .</TD></TR></TABLE>
Interesting...I may have to give all that a try. I still want a d16z6/y8...but good idea...
Vic
Vic
jdm.swift
29
Oct 29, 2010 01:14 PM
hatchinprogress
17
May 29, 2005 05:03 PM
