Portflow Inner\ITR Outter - Largest Cams??
Old Sep 5, 2005 | 12:05 PM
Suprdave's Avatar
Default Portflow Inner\ITR Outter - Largest Cams??
What is the Biggest Cams, and the highest anyone has rev'd that combo to?
I've seen Jun 3s @ 9300rpm...anyone seen anything larger?
I'm looking for 1st Hand Information here...thanks.
Old Sep 5, 2005 | 12:12 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Portflow Inner\ITR Outter - Largest Cams?? (Suprdave)
currently running pro 1's to 10,100 no problems, no lobe or pad wear
Old Sep 5, 2005 | 02:18 PM
Bserious's Avatar
Default Re: Portflow Inner\ITR Outter - Largest Cams?? (PURPLETERROR)
We ran 12.5mm of lift with this combo, taking to 9500 RPM. Titanium retainers still look good to, but this was a race setup documented with 74 passes.
Old Sep 5, 2005 | 03:35 PM
Suprdave's Avatar
Just the information I was looking for...thanks guys.
Old Sep 5, 2005 | 07:14 PM
ShaunRR's Avatar
HT White Ops
Community Builder
I believe Tbone has lots of experience with this setup as well.
Old Sep 5, 2005 | 07:45 PM
teg92's Avatar
Default Re: Portflow Inner\ITR Outter - Largest Cams?? (rochesterricer)
I am running this with stock ITR retainers as well with Skunk2 Stage 2 cams, no problems, everything runs great.
Old Sep 7, 2005 | 03:08 PM
Screamer's Avatar
I ran Jun stage 3's for about 25k km and everything was fine.
Old Sep 7, 2005 | 07:17 PM
Supernatural's Avatar
Default Re: Portflow Inner\ITR Outter - Largest Cams?? (Screamer)
i had skunk stage 3's with that combo...i took at a tad past 9k but i had a 92mm stroke
Old Sep 11, 2005 | 01:23 AM
oldskool teggy's Avatar
Default Re: Portflow Inner\ITR Outter - Largest Cams?? (SUPERNATURAL)
you ran 12.8mm lift and 270 duration on portflow springs? what retainers?
Old Sep 11, 2005 | 05:54 AM
CRVEF8's Avatar
run the type 4 up to 10,000 rpm no problems
on a drag car
friends B16a runs the type 3 up to the same rpm for a road car with no problems but street/strip car no worries
Old Sep 13, 2005 | 02:42 AM
Default Re: (CRVEF8)
type 4 what?
hybridpatient95
22
May 16, 2006 02:54 AM
dpine
May 19, 2004 03:37 PM
LudeToAHatch
10
Mar 19, 2004 09:06 AM
vtec94civic
Jan 14, 2004 06:43 AM
