96 auto tranny drain and fill hole
can someone post a pic of where the drain and fill hole for a 96 auto tranny is? i gota change my moms tranny fluid and these damn v6's confuse me, thanks
#18 is the drain plug (bolt) in the illustration provided.
http://www.hondaautomotivepart...USING
I can't find an illustration of the filler plug
P
P
the drain hole is what P_adams showed , you need a 3/8 rachet to remove plug,,,,,,,,the filler hole is located on top of tranny, you can see it below lower radiator hose , you need to remove dip-stick , if you just drain and refill put 3 qts of tranny fluid back in
JASIYAH6
Mar 9, 2009 10:05 AM
