Dented Cam ! Need Opinions please, Pics inside.
Old Sep 5, 2005 | 10:06 AM
Euro98ITR's Avatar
Default Dented Cam ! Need Opinions please, Pics inside.
Just received a set of ITR cams but the intake cam was a bit damaged in the top part.
Do you think that this needs to be fixed before installed (if fixable) or the dent doesn't hurt so much in that position.
Pics suck a bit - camera phone !
Old Sep 5, 2005 | 10:11 AM
mmuller's Avatar
Mad Scientist
Default Re: Dented Cam ! Need Opinions please, Pics inside. (Euro98ITR)
i would not use it..
They dropped it, so the rest of the cam could crack; they are very brittle as you see
Old Sep 5, 2005 | 10:31 AM
drdisco69's Avatar
That's also the surface that bears all the axial load on the cam, keeping it from sliding back and forth. A thrust bearing if you will. Shaped like that, it's more like a cheese grater for the head. It's also a stress riser, as well as an indication that they haven't been treated very nicely, as Max said.
Send them back, it's trouble waiting to happen.
Old Sep 5, 2005 | 10:55 AM
PURPLETERROR aka BIGMATT's Avatar
do not use that cam, looks like it was dropped, there could be more stress cracks that you cant see, and like drdisco69 said that chipped piece will cut into your cam caps. Its not wort risking it. I hope your package was insured.
Old Sep 5, 2005 | 11:06 AM
Euro98ITR's Avatar
Default Re: Dented Cam ! Need Opinions please, Pics inside. (PURPLETERROR)
Thats not very nice news guys ! Unfurtunately they where not insured. I examined the cams very well and dont seem to have any cracks on them. Do you think that it can be repaired?
Old Sep 5, 2005 | 11:36 AM
Flashmn's Avatar
Didnt you read any of the responses?
Clearly the major opinion is that it cant be fixed, I wouldnt take a risk of having it fixed and then have it break on me.
Old Sep 5, 2005 | 12:27 PM
BoOstedEM1's Avatar
They cant be fixed...your outa luck on this one man.
Old Sep 5, 2005 | 12:45 PM
drdisco69's Avatar
Default Re: Dented Cam ! Need Opinions please, Pics inside. (BoOstedEM1)
Yeah, even if you put the little piece back in, you still have a stress riser and possibly tiny cracks all over the thing. It will fail, and probably take a lot of stuff with it.
Old Sep 5, 2005 | 02:17 PM
mportbusta's Avatar
UH...ITS BROKE
Old Sep 5, 2005 | 05:50 PM
SiR_Mugen_00's Avatar
Default Re: Dented Cam ! Need Opinions please, Pics inside. (mportbusta)
It could throw the balance out if installed!
creating more problems in the future!
Old Sep 7, 2005 | 10:38 PM
db8xc1x39
Guest
Posts: n/a
Default Re: Dented Cam ! Need Opinions please, Pics inside. (SiR_Mugen_00)
no way in hell can u repair that thing. sorry to say but you got jipped. try and return them and let him know wassup. shady sellers those bastards
Old Sep 8, 2005 | 10:23 AM
Euro98ITR's Avatar
Default Re: Dented Cam ! Need Opinions please, Pics inside. (db8xc1x39)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8xc1x39 &raquo;</TD></TR><TR><TD CLASS="quote">no way in hell can u repair that thing. sorry to say but you got jipped. try and return them and let him know wassup. shady sellers those bastards</TD></TR></TABLE>
It was not the fault of the seller guy.. It was damaged during shipping .
Old Sep 8, 2005 | 11:28 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Euro98ITR &raquo;</TD></TR><TR><TD CLASS="quote">I examined the cams very well and dont seem to have any cracks on them. Do you think that it can be repaired?</TD></TR></TABLE>Cracks aren't always visible by normal inspection.
But if you try to weld a piece in where it's missing, then the camshaft will never be perfectly straight again. The heat of welding will warp it. Stress-relieving & re-doing the heat-treating will be more expensive than another camshaft.
Old Sep 8, 2005 | 11:52 AM
skunked's Avatar
Default Re: Dented Cam ! Need Opinions please, Pics inside. (JimBlake)
paper weight
Old Sep 13, 2005 | 02:31 PM
minimesleeper94's Avatar
a machine shop could very easily weld it back up and machine it. but just like everyone else said, there is the possibility of other cracks that you don't see. can't be used in that shape though.
Old Sep 13, 2005 | 06:35 PM
snowseeker's Avatar
Default Re: (minimesleeper94)
Little JB weld and it will be good to go again!
TurboSohc3369
Nov 5, 2007 05:50 AM
sundownz
Feb 9, 2007 10:07 AM
rough_draft
Mar 26, 2005 05:32 PM
shaunjdaniels
29
May 12, 2003 04:51 AM
