finally my hach is lowerd
i lowerd my hach yesterday install some tokico blues and a set of drop springs now of course my camber is negative im about to order a camber kit today but i thoght i should run this by u guys WHAT KIND OF CAMBER KIT SHOULD I GET???? any coments will be helpful thanks
damn dude, your never gonna get that camber in to be true. Unless you cut your inner fender and re-weld some supports in there. Or you can just cut away. I'm totally against cutting though.......................
i just boght some Motegi wheels and they happend to be 16's so ur telling me that even if i get an adjustabel front camber kit as well as the rear i will have problems with it????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel »</TD></TR><TR><TD CLASS="quote">i just boght some Motegi wheels and they happend to be 16's so ur telling me that even if i get an adjustabel front camber kit as well as the rear i will have problems with it????</TD></TR></TABLE>
hmm, 16''s huh, you got the camber bolts right. Well, mine is lowered 1.5 in the front and 1.75 in the back, with 17's. I have the a-arm barely touching the inner fender, and its in the green on the alignment machine. barely in the green. And your runnin 2.50 with 16's, might be a little prob, but, try it out first. I'm not tryin to discourage you bro
none taken dude i just got out of the camber kit thread on top of this one and there showing a control arm wher u can adjust the camber that what im thinking of getting now for the rear i was looking at this
that will give me more adjusment than what i need right?
it looks good, and be honest, handles better to me, but man, when those tires start showing wire, it doesnt justify
you can always to the washer trick for the rear. it works and does the same thing as those camber bolts do
hey Im useing the Eibach allignment kit for the rear and not sure what ima do up front might have to use bolts and washers *sigh* although i did see a thread a while back where someone took the skunk2 adjustable front control arm from a EG and fabed it to a ef control arm. You should search for the thread.
alotta people dont know this but when you lower your car you get alot of toe out which intern wares your tires faster... camber has little to do with it unless your drifting or burning out.... my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix »</TD></TR><TR><TD CLASS="quote">alotta people dont know this but when you lower your car you get alot of toe out which intern wares your tires faster... camber has little to do with it unless your drifting or burning out.... my .02</TD></TR></TABLE>
100% true.
Camber won't effect your tire wear nearly as much as the toe being off. Your car isn't lowered all that much, so don't worry about having a couple of degrees of camber....it will actually make it handle better. Get an alignment and have the toe set to spec or to 0 degrees on all 4 corners.
100% true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">HX wheels look good! hatch overall is very nice
yes sir they do bump for black hatch with hx's........i sold mine
i love the way they used to look on my rex. ex.
</TD></TR></TABLE>yes sir they do bump for black hatch with hx's........i sold mine
