Looking for "Free hp mod" post
Old Sep 5, 2005 | 12:27 AM
crashcritter_81's Avatar
Default Looking for "Free hp mod" post
I run acrossed a long post one night about running lines from your valve cove to a catch then to the exhaust, in the post was stock honda parts number for some of the parts needs for this mod and so on. Well I forgot to bookmark the page and now I can't for the life of me find it again. Can anyone lend a helping hand and help me find it. Thank in advance.
Old Sep 5, 2005 | 03:38 PM
ukdm crx's Avatar
Default Re: Looking for "Free hp mod" post (crashcritter_81)
HP isn't free so just forget it.
Old Sep 5, 2005 | 03:46 PM
SiR Inspired ED7's Avatar
free hp mod...
homemade intake yo
Old Sep 5, 2005 | 03:55 PM
redryder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashcritter_81 &raquo;</TD></TR><TR><TD CLASS="quote">I run acrossed a long post one night about running lines from your valve cove to a catch then to the exhaust, in the post was stock honda parts number for some of the parts needs for this mod and so on. Well I forgot to bookmark the page and now I can't for the life of me find it again. Can anyone lend a helping hand and help me find it. Thank in advance.</TD></TR></TABLE>
why dont you just go through your history in the toolbar up above.
Old Sep 6, 2005 | 09:13 AM
Your right Hp is not free or cheap for that matter, but that's not the point of my post.
As for redryder thank for the tip I didn't even notice that up there, but this was like 3-4 months.
Old Sep 6, 2005 | 09:41 AM
BrokenRex
Guest
Posts: n/a
post the site up critters
Old Sep 17, 2005 | 03:28 AM
All I had to do was remember how I run acrossed it in the first place. https://honda-tech.com/zerothread?id=1199935
Old Sep 17, 2005 | 07:32 AM
SwissChEz82's Avatar
Free HP mod? Where do they dig these weirdos up at???
Old Sep 17, 2005 | 09:47 AM
suspendedHatch's Avatar
Default Re: Looking for "Free hp mod" post (SwissChEz82)
I forget the name of what you're talking about, but basically you're trying to create a vacuum in the crankcase by sucking the air out through the exhaust. Obviously you need some one way valves. They also sell electric pumps for this purpose for the big V8 drag motors.
If you don't live in a freezing climate, you can bypass the coolant to the throttle body and idle motor. On an EF you simply remove the coolant hoses and loop the line that goes to the throttle body with the line that comes from the IACV. You don't have to plug anything. On an EG or a car with a FITV, you have to plug the FITV. I removed it and made a block off plate with some paper gasket material and shorter bolts. Reset the ECU and you may have to turn the idle adjustment screw. Any car that has an FITV will now take longer to warm up to OT, but there's no loping idle if you plug the FITV.
You can adjust some things to the "high side" of spec to safely get some free power. Ignition timing and a valve adjustment come to mind.
Running a thinner good quality oil is somewhat free hp if your motor is sealed up tight.
boostfever
Aug 22, 2013 12:06 PM
2gnarly
Oct 28, 2008 12:25 PM
Honda33442
Jul 22, 2006 02:38 PM
sigNAL_fiRE
Oct 11, 2005 08:08 AM
murcury
Apr 12, 2004 05:59 PM
