Backup Fuse (7.5) Question
Old Feb 26, 2002 | 10:19 AM
HaUTSaauce's Avatar
New User
Default Backup Fuse (7.5) Question
what does this fuse do exactly?
when i blew this fuse i had to imput my radio code everytime i started my car and my clock did not work but r there ne other things that this fuse does? Just curious
Old Feb 26, 2002 | 01:47 PM
OneSunkCivic's Avatar
Default Re: Backup Fuse (7.5) Question (HaUTSaauce)
this fuse is for the backup info for the ecu and the memory for your radio and clock if you pull this or blow it then it resets your ecu and radio presets and clock. if it keeps blowing you have a short somewhere.
Old Feb 26, 2002 | 02:07 PM
HaUTSaauce's Avatar
New User
Default Re: Backup Fuse (OneSunkCivic)
thanks
Old Feb 26, 2002 | 07:14 PM
BreakStuff's Avatar
New User
Depending on make/model/year.. the 7.5 amp backup fuse can share many components including the radio, dome light, cigarette lighter, intermittent wipers and sometimes doorlocks.. the most common cause for this fuse to blow is a faulty cigarette lighter element..
Old Dec 25, 2014 | 01:08 PM
aa62045's Avatar
Does anyone have a schematic of this fuse. I have an 08 Civic coupe LX and found that fuse was giving me a parasitic draw. I took out the radio and heater/AC but the draw was still happening. My issue is if the car sits there for more than 12 hours or a couple of days it won't start.
Old Jan 19, 2021 | 01:57 PM
mark Childers's Avatar
I have a 2007 Honda ridge lying I'm having the same problem the battery is being drained if I pull out this number 7 fuse this short goes away I had just installed a backup camera that plugs into the cigarette lighter do you think the cigarrette lighter could be causing the problem
shadowdawn
Mar 27, 2011 12:22 PM
mudd_butt
Apr 14, 2008 07:40 PM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
rcarpen22
Mar 21, 2006 07:42 AM
fanta!
Dec 28, 2005 02:52 PM
