My DC2 H22 Engine Swap Pictures
Just thought ill'd post pictures of the progress im making on my engine swap. Its a clean Integra gsr shell that i bought and droped in a H22A. Every thing is working really good from what i can tell, im not even getting the factory honda check engine light
j/k
Daniel
j/k
Daniel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomvroomcivic »</TD></TR><TR><TD CLASS="quote">wow impressive, also in the last pic your motor looks slightly crooked, illusion maybe? what p/s pump, line & Bracket did you use?</TD></TR></TABLE>
Engine is strait, its just the picture. Im using HCP mounts
That is the original jdm h22a ps pump and bracket that came with my motor. I polished it sence i had to grind the pump down alittle so the line would clear. Im also using the stock dc2 line.
thanks for the comments
ill try to answer the questions
im running the stock jdm h22a p13 ecu that came with the motor
those are tie wraps on the radiator only because i dont have the stock rad brackets to hold the radiator in place. Im going to buy them from the dealer soon.
ill probably in time add a/c to the car. the engine swap and the integra shell that i bought didnt come with anything for a/c, not even the lines in the engine bay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceCity_USA »</TD></TR><TR><TD CLASS="quote">What did you use for the white cover on the alternator wires?
Thanks,
Dave</TD></TR></TABLE>
Its white electrical tape. im not sure were you would buy it locally, maybe a hardware store would sell it, but i picked it up from work sence im a electrician. I also used red tape on the battery terminals and alittle blue tape on the harness garments which is behind the IM (i tryed to make the harness just like stock
Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neonorific20 »</TD></TR><TR><TD CLASS="quote">So there IS someone doing a H22 DC2! Awesome
Ben</TD></TR></TABLE>
there is a few here on HT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">
<------</TD></TR></TABLE>
I figured there were, but never saw anything posted about them. I had made a thread asking for pics of an H22 swapped DC2 but nobody seemed to know about anyone with this swap.
Ben
Ben
Same as an EG for the most part.
https://honda-tech.com/zerothread?id=1131655
mister2racer
37
Feb 21, 2004 03:49 PM
