civics?
Old Sep 4, 2005 | 09:23 AM
skata89's Avatar
Default civics?
Is a 97 stcok vtec civic anygood to spend money on? and on a engine with a header intake and catback exhaust. does ur car really go that much faster? and what would be hp gain with all of that?
Old Sep 4, 2005 | 09:25 AM
92ehatch's Avatar
Default Re: civics? (skata89)
u could turbo it, but if you want to go all motor i would suggest a motor swap with those bolt ons.
on a stock vtec engine, those bolt ons dont add that much hp, but noise goes up alot
Old Sep 4, 2005 | 09:32 AM
JDM-EJ1's Avatar
Default Re: civics? (93egsedan)
If you're planning on keep the D series, I would suggest boosting it. They can make quite a bit of power when they're boosted.
Old Sep 4, 2005 | 09:43 AM
SavEM1's Avatar
you are basically going to get nowhere with NA boltons as its not that powerful of a engine to start with (not that B-series are powerful)...I'd suggest you just boost the **** out of it. Push 15psi, if the engine blows you can replace the whole block for 400 tops
Old Sep 4, 2005 | 11:10 AM
nighttrain33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skata89 &raquo;</TD></TR><TR><TD CLASS="quote">Is a 97 stcok vtec civic anygood to spend money on? and on a engine with a header intake and catback exhaust. does ur car really go that much faster? and what would be hp gain with all of that?</TD></TR></TABLE>
There are SOHC Civics running 400 hp's. I have seen DOHC's running over 1,000's hp's. SOHC's are great motors, but they will never have the potential that a DOHC will simply because of more tuning options. Two cams instead of one. More stock power than the single cams. You can definitely still get great power out of a single cam if you build it and tune it right, but a DOHC will part for part, still make more power than an SOHC.
-Shane
honda_tuner26
Nov 11, 2022 05:52 AM
HondaDseries
Feb 19, 2015 09:57 AM
panchlow
Aug 19, 2010 12:18 AM
D15BHatchbackcivic
Aug 1, 2005 02:40 PM
DaKINE-Ek
11
Feb 27, 2004 08:05 PM
