Recommended parts for a 2002 DC5 Type S.
I know what parts to get but what are you using and how do you like it/gains?
What has been proven to produce the best gains for TB, IM, Header and Exhaust?
NA first possibly boost later...I want to race and can't boost and run some of the circuits around here. I know what parts to get, I am just asking what brands per part have been showing the best gains and durability.
best gain i got out of an intake mod is adding the PIMP to my intake manifold. it basically bolts onto the bottom of the intake mani and increases the IM volume. gives great mid range and a bit of low end. i think the creators clained 10 ft/lbs of wtq and 4 hp... otherwise u can combine that with a cold air intake and definitely think about upping the exhaust manifold to a race header b/c the stock one reminds me of a d series header... also ecu upgrade is a must
You talking about a Plenum Spacer?...did you get a TB Spacer too?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00STidDc5 »</TD></TR><TR><TD CLASS="quote">best gain i got out of an intake mod is adding the PIMP to my intake manifold. it basically bolts onto the bottom of the intake mani and increases the IM volume. gives great mid range and a bit of low end. i think the creators clained 10 ft/lbs of wtq and 4 hp... otherwise u can combine that with a cold air intake and definitely think about upping the exhaust manifold to a race header b/c the stock one reminds me of a d series header... also ecu upgrade is a must</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voiddweller72 »</TD></TR><TR><TD CLASS="quote">NA first possibly boost later...I want to race and can't boost and run some of the circuits around here. I know what parts to get, I am just asking what brands per part have been showing the best gains and durability.</TD></TR></TABLE>
I would say unless you have alot of money to make up your mind and be as sure as you are going to be now. Dont spend money on an Intake and Header and then decide to go boost.
Ok, let me rephrase that. I want to run NA for a while then possibly end up boosting....but NA will be with me for quite a while. I plan on installing all of the Type-R parts that my S is lacking and possibly putting on the PRC IM and CRV bottom end with a nice slip diff.
DJLikwid
May 8, 2007 03:41 PM
