Swapping seats help!!
Old Sep 4, 2005 | 06:13 AM
tomu06's Avatar
Default Swapping seats help!!
the search engine is down, so i thought i could get some info from you guys. i just got a 93 cx, and my friend has 99' Gs integra w/ leather. He wants the cloth interior, i want the leather interior for now. we tried yesterday, and only 3 of the bolts lined up. is there a trick of the trade, or do we have to switch railing? anything helps.. ty
Old Sep 4, 2005 | 11:01 AM
tomu06's Avatar
Default Re: Swapping seats help!! (tomu06)
ttt
Old Sep 4, 2005 | 07:19 PM
tomu06's Avatar
bump
Old Sep 4, 2005 | 07:36 PM
JDM PRO's Avatar
i think you would have to swap rails
Old Sep 4, 2005 | 07:37 PM
BlueIntegraBoy's Avatar
Is his a sedan? Anyways, they should be interchangeable as it is. If not, you can swap the inner rails from each seat. You'll need like a 10mm, 12mm, and I believer 14mm sockets to remove the inner rail.
But sometimes if you have 3 bolts tight, the 4th won't line up. Make sure all the mounting holes are loose so you can maneuver the holes.
Old Sep 5, 2005 | 03:01 PM
tomu06's Avatar
Default Re: Swapping seats help!! (BlueIntegraBoy)
still wont line up plz help
Old Sep 5, 2005 | 03:08 PM
MonkeyBoy668's Avatar
You probably could swap seat pans & rails.
Only hitch is if the pans aren't the same size.
Old Sep 5, 2005 | 03:47 PM
97civicdx's Avatar
Default Re: Swapping seats help!! (MonkeyBoy668)
swap out the inner rails. Teg seats should line up perfectly to a 92-95 civic.
byc_cb7
Feb 23, 2010 04:35 PM
LatinEM2
Honda Civic (2001 - 2005)
73
Feb 6, 2010 11:56 AM
FSUseminoleEM1
Dec 17, 2009 10:21 AM
grandam
Mar 25, 2008 04:17 PM
dividedas1
May 24, 2006 12:09 PM
