Is my tranny dead?
Old Sep 3, 2005 | 10:36 PM
marc-111's Avatar
Default Is my tranny dead?
i used a 6 puck act clutch and pressure plate and went to track with street tires, i was on the staging lanes and when the green light turned on and i released the clutch my linkage fell off and the one in the picture was cut-off with my linkage and transmission oil was dripping, do i only need to change the chasing or just buy a new tranny? is there any damage on the transmission besides that one like the gears and other parts in the transmission?
thanks!
Old Sep 4, 2005 | 05:51 AM
marc-111's Avatar
any?
Old Sep 4, 2005 | 06:21 AM
Reis's Avatar
bump
Old Sep 4, 2005 | 10:07 AM
R-Toyz.com's Avatar
needs more pics
Old Sep 4, 2005 | 09:05 PM
R-Toyz.com's Avatar
Study the diagram below:
http://www.acuraoemparts.com/d...ch=no
Based on the picture you showed you may have broken a bolt that holds the linkage. Shouldn't be too expensive to repair. Who knows it may just be a bolt that came loose. That's what I think given the pic you showed.
Post more detailed pictures of the tranny housing, the damaged shift linkage, and other areas that you think will help clear this up.
At this point I don't see the need for you to change the whole housing. If you have the time drive up here to CT and bring along the tranny. We can meet up at Jinky's during the weekends. There is an Acura dealership nearby who hopefully stocks the parts we need to get this over with and do the repairs in the driveway.
Old Sep 5, 2005 | 04:08 AM
R-Toyz.com's Avatar
Just to clarify the terms...
I believe it was your extension rod that came off...and not the shift rod.
Do me a favor....look at encircled area and take pics of it...now let me know if you can find a hole with threads in it.
If you can find that...then that means it was just a bolt that came loose. Go to your Honda/Acura dealership and buy the bolts and shims for the extension rod. Put back that tranny...and bolt everything back.
Hope this helps.
Old Sep 5, 2005 | 08:25 AM
mmuller's Avatar
Mad Scientist
Default Re: (rtzcom)
you can find a case and swap it.
If not find a --good-- al. welder and they can weld that shift rod stabilizer thingy back
Old Sep 5, 2005 | 03:09 PM
R-Toyz.com's Avatar
I know someone up here who can do aluminum welding
Old Sep 5, 2005 | 05:25 PM
marc-111's Avatar
ill just change the casing, hopefully by this week i could bring my car back in the road!
here's the actual pix with the engine rear bracket bolts broken too
my problem is how to remove that casing! it's hard as ****! i only did separate then like half an inch
Old Sep 5, 2005 | 06:15 PM
SpeedDreamz.com's Avatar
Default Re: (marc-111)
you will definitely need a case. You should not have any damage inside.
Old Sep 5, 2005 | 06:59 PM
marc-111's Avatar
internal pix
i dont know if its still ok? could you check it? all the gears seems ok no grinds,
Old Sep 5, 2005 | 07:07 PM
DaveF's Avatar
after the gears/ differential come out, you will be able to see the damage.
Old Sep 5, 2005 | 07:40 PM
marc-111's Avatar
so i need to remove it piece by piece then?
when i put it back on is there like a particular setup for each piece? like this should be aligned to this and so? or there is like a marking on every piece?
Old Sep 5, 2005 | 07:46 PM
DaveF's Avatar
remove this thing at the bottom right first
then, remove this
then take this small gear out. it comes out with the small shaft.
after all that stuff is out. take both of your hands and place them over the shifter forks and gears... about in the middle or so... and lift them straight out.. then place them on a rag or something.
after the gears are out, the differential is next to come out.. these are usally in there kinda tight, so you might have to flip the case on its side, and wack the case or get a large socket, and wack it out.
Old Sep 5, 2005 | 08:00 PM
marc-111's Avatar
ok thanks a lot! will do that tom after school, will update this again tom or so
Old Sep 5, 2005 | 09:22 PM
R-Toyz.com's Avatar
Before you start taking it apart...try getting a Helm's manual...in case something falls off or you lose track while in the disassembly or assembly process.
Hopefully you can get by with just the case...the cost of repairing the internals of the tranny piece by piece makes it more practical to just buy a used one.
If you need parts like the gearsets and syncros...try checking out gearspeed.
Good Luck with your rebuild
It's funny how your fellow Honda owners from Sigma Auto aren't chiming in at all in this issue. Oh I forgot this isn't the Cosmetic and Appearance forum
Modified by rtzcom at 3:50 PM 9/6/2005
Old Sep 6, 2005 | 10:08 AM
marc-111's Avatar
in this picture i could not remove the bearing on top right? and there are 2 washers underneath right? the other one is bigger than the other washer, when i put it back which one is on the bearing side and the one on the gear side?
Old Sep 6, 2005 | 10:32 AM
DaveF's Avatar
the big washer has a "tooth" on it, it faces downward, and fits into a slot on the piece below it.
Old Sep 6, 2005 | 10:35 AM
marc-111's Avatar
Default Re: (Dturbocivic)
Modified by marc-111 at 12:53 PM 9/6/2005
Old Sep 6, 2005 | 10:48 AM
marc-111's Avatar
i got it already the bigger washer goes to the countershaft and the smaller washer goes to the mainshaft, im almost done! thanks!
Old Sep 6, 2005 | 11:52 AM
marc-111's Avatar
on putting the differential back on does it have a tooth to go in too or as long as i lock it up thants good?
how about the rubberseal outside and differential it has like a half inch gap between them?
and is there a trick on how to put back all the shafts? its really hard
Old Sep 6, 2005 | 11:09 PM
marc-111's Avatar
im in the last pc to install in my tranny, but i think i lost something like this i think encircled in the 2nd pix
Old Sep 7, 2005 | 03:54 AM
DaveF's Avatar
that is an odd looking piece on there, are you sure its not a part of the shift fork or something?
Old Sep 7, 2005 | 05:06 AM
marc-111's Avatar
nope i also checked acura parts i dont see that piece, and if i bolt it up without that one and when i shift it the whole thing would be disaligned
Old Sep 7, 2005 | 05:29 AM
DaveF's Avatar
you have to put the shifter in, so that it fits in the middle of the spot on the shifter fork. align all the shifter forks together, so they all match up where the mechanism fits in. than install the shifter mechanism. the shifter mechanism slides up and down, as well as side to side, depending on which way you move it will determin what gear its in.
