B20 vtec head gasket?
Old Sep 3, 2005 | 01:14 PM
Dan-Dillinger's Avatar
Default B20 vtec head gasket?
y0, im helping out a friend do a B20 swap into a DA integra. We are using the B20Z block with the b16a cylinder head. Ive tried searching but the H-T search function is down. People say you can use the LS gasket? What is the LS? I stay in the UK so your model codes are different from here.
Is there any other gaskets that could be used bar the golden eagle one?
Thanks in advance guys
Old Sep 3, 2005 | 10:21 PM
SPOON_FED_DC_2's Avatar
Default Re: B20 vtec head gasket? (hondacivicEK)
My friend and i are both using b20 headgaskets. I dont think u can use the LS (b18b) headgasket cause the bore is different.
Old Sep 3, 2005 | 10:25 PM
RudeBwaiSi's Avatar
B20 headgasket.
Old Sep 4, 2005 | 03:41 AM
Default Re: (RudeBwaiSi)
so the b16 head gasket can't be used at all?
How do you go about enlarging the dowel holes on the b20 gasket?
Thanks
Old Sep 4, 2005 | 06:35 AM
RudeBwaiSi's Avatar
B16 head gasket cannot be used. Machine shop can enlarge the dowel holes. Or you could try using a dremel to see if you can DIY.
Old Sep 4, 2005 | 06:53 AM
fmrprojects's Avatar
use a b20 headgasket. If you use a b18(LS) or b16 the piston will hit the gaket
Old Sep 5, 2005 | 03:35 AM
KingHornet's Avatar
Default Re: (fmrprojects)
You cannot use your B16 (or B18) gasket on your B20 block. B16 bore is 81mm and the bore of the B20 is 84mm.
Old Sep 5, 2005 | 03:51 AM
jdmek20's Avatar
Default Re: (ChampWht)
b20 head gasket. or a cometic head gasket
Old Sep 5, 2005 | 09:10 AM
f@sth@tch89's Avatar
Default Re: (jdmek20)
b20 head gasket all day all night....i have a b20vtec w/ gsr head...chambers opened to 84mm to match the bore.
Old Sep 5, 2005 | 09:57 AM
PogKai's Avatar
yup B20 headgasket.. I have one for sale.
Old Sep 5, 2005 | 09:58 AM
PogKai's Avatar
Default Re: (f@sth@tch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f@sth@tch89 &raquo;</TD></TR><TR><TD CLASS="quote">b20 head gasket all day all night....i have a b20vtec w/ gsr head...chambers opened to 84mm to match the bore.</TD></TR></TABLE>
why did you do that? you just lowered your compression
Old Sep 5, 2005 | 12:08 PM
Default Re: (PogKai)
im running 14.1 on the pistons.....still made good hp on the dyno
Old Sep 5, 2005 | 12:58 PM
Supa_Slow_Civic's Avatar
You need the b20 head gasket
Old Sep 5, 2005 | 01:39 PM
DonF's Avatar
Default Re: (Supa_Slow_Civic)
B-20 head gsk., and you enlarge the holes in the head to accept the dowels, in the same holes as the b20 block, opposite side. Plus block the oil hole in the head 1/8 pipe tap.
blackcrx16
Feb 28, 2008 04:04 PM
crx1856
Jul 21, 2003 03:27 PM
Shft@9GSR
Oct 4, 2002 12:10 PM
Shft@9GSR
Oct 3, 2002 09:46 AM
Ri5e
Feb 28, 2002 10:25 PM
