need help clutch problems
hey whats up H-T i have a 93 accord se i resently change the clutch on it about 1000miles ago ever since i change the clutch the gears will go in a little ruff i would have to force then in, now no gears go at all, i tod it was the clutch cylinder and the slave cylinder so i change and bled then real good but still no gears go in. i pull the tranny out look at the clutch again and it looks good i dont know what do please help, did this happen to anyboby ? and the clutch is exedy.
What concerns me is that it didn't work correctly from the day you had it installed. Who ever suggested the clutch Master/slave bleed was correct in going there first, but since the condition has sinse worsened, I suspect either you're loosing travel in the clutch release system (clutch Master/slave), or the pressure plate may be at fault.
You should feel definite resistence from the very start from pushing the Clutch release pedal. If you don't, you've got either air in the system (again) or one of the components may be leaking internally.
The pressure plate fails primarily when the circular diaphram spring deforms or looses temper and doesn't allow the clutch to fully release.
Number #5 in the supplied illustration
http://www.hondaautomotivepart...ERTER
Not uncommon on aftermarket (replacement) clutch kits.
Recheck the release mechanism first.
P
P
Stonage07
Mar 6, 2017 11:48 AM
DenisR
Feb 19, 2016 05:09 PM
gsr camel
Sep 13, 2001 12:05 PM
